1.3.4 used to work. won't open. reinstalled-still won't open
JeffB
Post by JeffB » Mon Apr 21, 2008 3:30 pm
Hi,
I've used 1.2.6, then 1.3.3 and updated to 1.3.4 some time ago with no major issues other than an occasional crash.
Yesterday, however, I was unable to load 1.3.4. It shows in the taskbar at the bottom of the screen but I cannot ever open it to use it. Right clicking on the icon in the taskbar does nothing. It used to offer options to minimize (or restore) it, or close it etc. Now - nothing.
I uninstalled Audacity via the Window utility and then did a reinstall, but still no go.
I closed all of the programs, did a restart on the computer, double clicked on the Audacity icon, but came up with the same result. Then I shut down the computer completely, let it sit for a little bit and then restarted it again, but once again with the same result.
Here is a clip of a screenshot of the resources being used by Audacity as noted by "Process Explorer".
Any help anyone could give would be most appreciated. -- Thank you.
screenshot of process explorer showing system resources being used by running programs.
Re: 1.3.4 used to work. won't open. reinstalled-still won't
Post by steve » Mon Apr 21, 2008 6:45 pm
The first thing that I would try, is resetting Audacity 1.3.4 by deleting the configuration file.
The file is called "audacity.cfg" and its default location is:
Documents and Settings<user name>Application DataAudacityaudacity.cfg
Audacity will create a fresh configuration file when you next start it.
JeffB
Post by JeffB » Mon Apr 21, 2008 7:02 pm
stevethefiddle wrote:The first thing that I would try, is resetting Audacity 1.3.4 by deleting the configuration file.
Mucho thanks!
That worked like a charm.
OggOrbisRecords
Post by OggOrbisRecords » Sat Jun 21, 2008 12:51 am
and if for some reason you can't find that file, you can right click on the icon (on the bottom bar) and click maximize. :D
Paul
steven75
Post by steven75 » Sat Jul 12, 2008 2:33 pm
JeffB said: It shows in the taskbar at the bottom of the screen but I cannot ever open it to use it. Right clicking on the icon in the taskbar does nothing. It used to offer options to minimize (or restore) it, or close it etc. Now - nothing.
It looks like you computer stoped responding (hang). Did you try to restart it ?
Steven, you can find my web site here
Lemon
Post by Lemon » Wed Jul 16, 2008 5:10 am
I currently have the same exact issue... it's not a matter of clicking 'maximize', the screen just doesn't appear... I'll open the program, it sits on the task bar, and never brings up the main window. Deleting the audacity.cfg seems to be the only way to fix it.
LeRoc
Post by LeRoc » Sat Jul 19, 2008 1:12 pm
I had the same problem. Clicking on maximize works - for now. I'll try removing the cfg file later.
Post by steve » Sun Jul 20, 2008 3:49 pm
I've noticed that this issue can sometimes be created by rapidly clicking (more than 2 clicks) on the launch icon, resulting in 2 or more instances of Audacity trying to open simultaneously, and creating a kind of logjam, where the program appears on the task bar, but can not be opened or maximised.
I have real trouble with touch-pads on laptops, so being aware of this issue, when using a laptop I launch programs with "Right Click > Run" rather than "double left click".
flyfischerjim
Post by flyfischerjim » Thu Aug 14, 2008 6:58 am
I have the same problem with 1.3.5 . For a while I was able to use the program but after having a few crashes in trying to use noise reduction the system always seems to insist that there is another audacity program running. it shows in the taskbar but clicking on the taskbar item doesnt bring the program up to the screen. doing cntrl-alt-del says that the program is waiting for a response but there is nothing on the screen to respond to. 1.2.6 is co-existing with 1.3.5 but the latter is completely non functioning. I am using xp pro
flyfischerjim
Post by flyfischerjim » Thu Aug 14, 2008 7:13 am
getting rid of the cfg file allows the program to reappear -- that problem solved. thanks "stevethefiddle"
