Decode tapes using Dolby Noise Reduction
I have several reel to reel tapes that have been encoded with dolby noise reduction B, but do not have a machine that will decode it. I'd like to make digital copies with Audacity, and am wondering if there are any plug-ins or any other means to achieve this without having to buy a machine with dolby B.
- Quality Assurance
Re: Decode tapes using Dolby Noise Reduction
I only ever knew one plug-in that attempted Dolby de-emphasis but that is no-longer available. So in a nutshell, reduce the volume level of the high frequencies using Effect > Equalization. This is lot less fiddly if you use Audacity Beta.gmushlin wrote:I have several reel to reel tapes that have been encoded with dolby noise reduction B, but do not have a machine that will decode it. I'd like to make digital copies with Audacity, and am wondering if there are any plug-ins or any other means to achieve this without having to buy a machine with dolby B.
You can find the Dolby-B decoding curves near the bottom of this page:
http://hyperphysics.phy-astr.gsu.edu/HB ... tape5.html
Something in shape like the middle curve on the decoding graph but a little more pronounced and right-skewed would be reasonable. Once you draw a suitable Dolby-B decoding curve in Audacity Beta you can save it as a preset and reapply it easily without having to redraw it each time.
Dolby is a dynamic compander system. Compression and expansion of frequency response depends on the volume of the performance, so you can't just "roll off the highs" and call it good. Or you can call it good, but it won't be.
As you no doubt have already found, there are pages and pages of Googles starting with, "I have Dolby B tapes..." and followed by long threads of sympathy and explanations, but with no links.
I know of no Dolby A, B, or C plugin -- even open source. Dolby AC3 surround, yes. but not straight stereo audio.
<<<I only ever knew one plug-in that attempted Dolby de-emphasis but that is no-longer available. >>>
Under what circumstances?
It's a little worse that you think. Dolby B is the top processor from Dolby A. It has a sliding turnover frequency, IIRC 500 to 2KHz and its a compander in that low level HF was boosted up to 10 dB and loud HF boosted 0 during record encoding and the reverse during playback. Your processing has to change both the gain and the turnover frequency to properly decode it.
- Quality Assurance
Don't know what you mean by "circumstances", and I don't have any details to hand, but the plug-in claimed to do downward expansion of the quieter high frequencies as you suggest. My "in a nutshell" should definitely be read "as a compromise", but far better for gmushlin than doing nothing. That said, you can probably get Dolby-B tape decks fairly cheaply on eBay.kozikowski wrote:<<<I only ever knew one plug-in that attempted Dolby de-emphasis but that is no-longer available. >>>
billw58
Dolby B reel-to-reel decks?Gale Andrews wrote:That said, you can probably get Dolby-B tape decks fairly cheaply on eBay.
A google search turned up the TEAC AN-60 external Dolby B decoder unit. None available on eBay worldwide.
-- Bill
billw58
Don't know about the sliding turnover frequency, but the high-frequency band in Dolby C was above 9 kHz.kozikowski wrote: Dolby B is the top processor from Dolby A. It has a sliding turnover frequency, IIRC 500 to 2KHz and its a compander in that low level HF was boosted up to 10 dB and loud HF boosted 0 during record encoding and the reverse during playback. Your processing has to change both the gain and the turnover frequency to properly decode it.
From wikipedia:
This is my recollection. IIRC Dolby B was deliberately designed so that if you have a Dolby B encoded cassette and no Dolby B deck to play it on, you can get "acceptable" results by turning down the treble control on your stereo.Dolby B was developed after Dolby A as a single sliding band system providing about 9 dB noise reduction (A-weighted), primarily for cassettes. It was much simpler than Dolby A and therefore much less expensive to implement in consumer products. Dolby B recordings are acceptable when played back on equipment that does not possess a Dolby B decoder
This is about as good as it is likely to get for the OP unless he can lay his hands on a TEAC AN60 external Dolby B encoder/decoder.
There is one other (remote) possibility. If the OP knows an electronics hacker, it should be possible to hack up a cassette deck and inject the signal from the R2R into the appropriate point in the playback signal path and decode the Dolby B that way.
-- Bill
- Quality Assurance
Yes I've definitely seen them from time to time and they were (when I saw them) pretty inexpensive (under $100). There is a (Dolby version not specified) reel-to-reel tape recorder on eBay here, but certainly not cheap...billw58 wrote:Dolby B reel-to-reel decks?Gale Andrews wrote:That said, you can probably get Dolby-B tape decks fairly cheaply on eBay.
<<<Don't know what you mean by "circumstances">>>
Circumstances. Like: "I was Director of Engineering for IBM Content Management around 2002 and one of the participants in the "Skunkworks" outside of Poughkeepsie NY, wrote a Dolby B decoder module on the back of a Piggly-Wiggly napkin and brought it to work.
Richness of detail like we're always trying to get our posters to give us.
