Previewing result of deletion before deleting
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
DickN
Post by DickN » Tue Sep 21, 2010 11:19 pm
Am I nuts, or did I read somewhere that you can select a region (and maybe do a cut), and then listen to the track(s) with the selected region deleted? I even think I remember there being a way to set how many seconds on each side of the selection to play. But darned if I can find the writeup now! The place I found this had gobs of useful information, but apparently I neglected to bookmark it.
Edgar
Forum Crew
Re: Previewing result of deletion before deleting
Post by Edgar » Wed Sep 22, 2010 1:07 am
You want Preview Cut. I do not see it in any menu but it can have a shortcut key. There is a setting in prefs which controls the pre- (and seperately post-) preview times.
-Edgar
running Audacity personally customized 2.0.6 daily in a professional audio studio
occasionally using current Audacity alpha for testing and support situations
64-bit Windows Pro 10
billw58
Post by billw58 » Wed Sep 22, 2010 1:32 am
http://manual.audacityteam.org/index.ph ... _Recording
Scroll down to "Special Playback Keyboard Commands".
-- Bill
DickN
Post by DickN » Wed Sep 22, 2010 3:48 am
Thanks!
