The Visual Graph [SCREEN SHOT]
futures
Post by futures » Sat Sep 18, 2010 4:21 pm
Hi,
I was just wondering if there was a way to change the visual graph?
im currently using the default one..
and the sound the i record is basically a ticking noise that ticks every 1 second.
this ticking noise is VERY short..
so..
i can BARELY see it on the graph...as it shows up as a very skinny line.
so i was wondering if i could change the graph to a different pattern...or like a line graph or something else?
Is there a way?
and i need to record and watch the graph moving in real time.
Which i can do now, except its just hard to see that little skinny vertical line...every 1 second.
Please let me know asap.
thanks.
as u can see in the screen shot..
the line is super thin..
i can barely see it, nor can i even compare the spaces in between them..
so im just wondering if theres another way to view this graph thing.
please help me out
Re: The Visual Graph [SCREEN SHOT]
Post by kozikowski » Sat Sep 18, 2010 10:03 pm
Everybody always leaves out Step One. What's the show? What is the purpose of your recording? You can Effect > Amplify > OK and that will increase the size of the waves and make them a little easier to see.
You can drag-select a chunk around one of them and Control-E magnify that portion. Would that be helpful?
You're also missing the other part of the show. My goal is: What? Many times we can offer shortcuts if we know exactly what you're trying to do.
Post by steve » Sun Sep 19, 2010 2:16 pm
You can zoom in/out using the zoom buttons:
Other methods for zoom:
View menu > Zoom in/Zoom Normal/Zoom out
or
Ctrl+1 = Zoom in
Ctrl+2 = Zoom Normal
Ctrl+3 = Zoom out
or
Ctrl+mouse wheel.
