i'm using samson q1u. The version of audacity is irrelevant as the situation is the same in other audio applications i use (renoise, windows recording tool and so on...). the problem is therefore unrelated to audacity, but still some of you sound recording geeks here may help
I don't get audio in single channel, instead it's the same as described in the first post here - left channel is louder, right channel is weaker. I did overcome the problem using the method you described, recording only from the left channel as mono, but still - if the default record format in recording application is set to stereo and the input signal is mono, then i should have two equal signals on both left and right channels, just as i had when i was using some other cheap mic on Wavelab some time ago. And how do you interpret the panning behaviour i described? the operating system - windows xp.
I expressed myself in a wrong way - my problem seems EXACTLY the same as the one described by the author of this topic, and there seems to be no solution reply, so that's why I posted it here.
I was beggining to suspect it was a hardware malfuction but seeing some other guy having exactly the same issues made me wonder.
Maybe the usb cable is damaged? I'm a noob here.
maybe i should just ask samson's technical support
