New user question.
New user question.
so i decided to download audacity, just for the fun of it. actually, i have this one song from a cd that i want to edit, but i have no clue how to do. it's a medley of songs, and i want to separate a certain part out so i can just listen to that one part without having to listen to all the songs. how would i do that?
Re: New user question.
Highlight the part you want to separate out.
Export selection.
Yep, it's that easy.
Export selection.
well how do i get that song into audacity? like i said, i'm new and have NO CLUE.
"File > Import"stoco10 wrote:well how do i get that song into audacity? like i said, i'm new and have NO CLUE.
[EDIT] - oops, that's for Audacity 1.3.x
For Audacity 1.2.6 it's in the Project menu.
A great way to get to know Audacity is to work through some of the tutorials:
http://audacityteam.org/wiki/index.php?title=Tutorials
slight problem. there is no import option under file.stevethefiddle wrote:"File > Import"stoco10 wrote:well how do i get that song into audacity? like i said, i'm new and have NO CLUE.
There should be, unless you have some weird display problem. Alternatively, if the file is a WAV or MP3 you can simply use File - Open to load the file into Audacity.stoco10 wrote:slight problem. there is no import option under file.
The Import Audio option is under PROJECT at the top of Audacity , then simply select the file that you want to import .
