pdxrunner
Post
by pdxrunner » Thu Sep 16, 2010 7:02 pm
coonsanders wrote:hi guys
i downloaded the denoisier but im not getting how to use it..i looked at the documentation but its a little over my head..has
anyone ever used it and can give me an easier step by step way to do it id appreciate it.
lenny
I use Brian Davies' deNoise. Check this thread for the basic workflow that I use:
http://forum.audacityteam.org/viewtopic ... 28&t=37275
PDX
coonsanders
Post
by coonsanders » Thu Sep 16, 2010 7:32 pm
hi
i was noodeing around with the declicker and i think i got the hang of it.i put it on automatic instead of manuel and i think it cleaned the tune up ok.i also did notice
that u cant zoom in to get sample noise..what u got to do is when the tune starts
you have to stop it fast and highlight the lead in groove and let it process it from
there.if i did it right it didnt seem to be too hard.that clickrepair is amazing isnt it?
i plan to buy both eventually.thanks..
coonsanders
coonsanders
Post
by coonsanders » Sun Sep 26, 2010 10:51 am
hi fellas
i tried using the denoiser and found that you have to stop the process when the song starts then
you highlight that part of it and then procede from there.if u dont catch it then you have to sta
-rt the process again..but in order for you to get a noise sample you have to stop it before it ad-
vances to far into the song...i hope u know what im mean...and what is denoiserLF?it came wi-
th the denoiser...
lenny
ignatz
Post
by ignatz » Sun Sep 26, 2010 2:59 pm
Lenny:
DeNoise LF is explained in the downloadable manual for DeNoise (DNManual.pdf), which you can find on Davies' site.
It's for reducing VERY low frequencies. You may or may not need it, but if you want to use it Davies recommends that it be the FIRST step in processing a file.
coonsanders
Post
by coonsanders » Sun Sep 26, 2010 3:09 pm
hi
ahhh i c..thanks.
lenny
coonsanders
Post
by coonsanders » Mon Oct 11, 2010 8:42 pm
hi gang
i sent 40.00 to kagi for a serial number but im a little curious about kagi...are they relyable?i
sent the 40.00 to them and they are supposed to send me the serial number..can i rely on them?
lenny
waxcylinder
Post
by waxcylinder » Tue Oct 12, 2010 10:05 am
I boughy my copy of CR through Kagi and it worked fine - they sent an email with the registered user name and the required key. No other monies were taken from the account. So yes they seem reliable.
coonsanders
Post
by coonsanders » Tue Oct 12, 2010 10:44 am
hi
thanks waxy...am awaiting the serial key..all i need is the noise remover tool...thats next.
lenny
coonsanders
Post
by coonsanders » Wed Oct 13, 2010 5:21 pm
hi guys
i got the serial number for click repair but i cant seem to install it into the register part of the software..the email said try pop and click but they are grayed out..is there a way to un gray them or what else can i try?thanks.
lenny
