a pop and click remover
coonsanders
Post by coonsanders » Mon Sep 13, 2010 8:28 pm
hi gang
im having an issue with the pop and click in both audacity and goldwave..they dont seem to
get rid of the pops and clicks.is there a different software that i can try and if i like it i can
buy it thatll get rid of pops and clicks?thanks.
coonsanders
ignatz
Re: a pop and click remover
Post by ignatz » Tue Sep 14, 2010 2:51 am
Yes:
Brian Davis ClickRepair; 21 day free trial, $40 if you want to keep it.
http://www.clickrepair.net/
I haven't tried the following, but have heard good things about them:
Diamond Cut Millenium; $59
http://www.diamondcut.com/store/index.p ... ducts_id=7
http://www.diamondcut.com/Catalog/millennium.htm
Magix Audio Cleaning Lab; $50.
http://www.magix.com/us/audio-cleaning-lab/
coonsanders
Post by coonsanders » Tue Sep 14, 2010 10:28 am
thanks...clickrepair is a good software?
lenny
waxcylinder
Post by waxcylinder » Tue Sep 14, 2010 10:48 am
IMHO it's more than good, it's a little shy of being magic - see this sticky thread: http://forum.audacityteam.org/viewtopic.php?f=28&t=1994
coonsanders
Post by coonsanders » Tue Sep 14, 2010 12:22 pm
hi guys...
its very good..i just did a 78 in need of cleaning and it cleaned up like a shot..and its so easy to use too.better than gold wave vand audacity..thanks..
lenny(u know me better as coonsanders)
waxcylinder
Post by waxcylinder » Tue Sep 14, 2010 12:45 pm
Lenny, as you are processing 78s you might also want to look at Brian Davies' other piece of software - DeNoise. It costs another $40, but like ClickRepair you do get a 21-day free trial,
It's not quite as easy to use as CR but it does produce some good results when used carefully.
coonsanders
Post by coonsanders » Tue Sep 14, 2010 2:49 pm
hi
yea i was just going to ask is his other stuff as good as cr....do u know anything about that?
lenny
ignatz
Post by ignatz » Tue Sep 14, 2010 3:42 pm
Lenny:
I evaluated DeNoise and DeNoiseLF a few weeks ago and concluded I would not buy them. Actually, those 2 apps are part of 1 package.
Not because they don't work---they do, and quite well. But Audacity noise reduction works quite well also. And I found DeNoise not suitable for me in one respect: it's difficult to grab a small noise sample with the mouse because you cannot zoom into a track like you can in Audacity. That probably isn't a problem if you have several seconds of noise available, but if you have less than a second, that represents a very small piece of screen width and it's difficult to see it clearly or grab it.
Your mileage may differ and you can test it for nothing. Several people here have purchased DeNoise and are quite happy with it.
I will say that the batch processing in his applications is excellent---as is the documentation. DeNoise and DeNoise LF are easy to use and don't have 50 controls. The defaults work pretty well.
Which reminds me:
I downloaded a trial version of Magix Audio Cleaning Lab 16--their most recent package.
Utterly useless. It may "work" very well, but the interface is so confusing and convoluted that I could see it would have a VERY steep learning curve. Dozens of doodads and drop downs with no apparent logical order or intuitiveness. And the documentation was mediocre. I'd avoid it entirely.
coonsanders
Post by coonsanders » Tue Sep 14, 2010 4:27 pm
hi
thanks 4 the info...ill probably just the declicker 4 now..
lenny
coonsanders
Post by coonsanders » Wed Sep 15, 2010 11:20 pm
hi guys
i downloaded the denoisier but im not getting how to use it..i looked at the documentation but its a little over my head..has
anyone ever used it and can give me an easier step by step way to do it id appreciate it.
lenny
