"reference to invalid character number at line 6"
Re: "reference to invalid character number at line 6"
Yes, there shouldn't be any problems with non-alphanumeric characters in more recent versions of audacity, nonetheless I always prefer to stick to the basic alphanumeric characters for the sake of compatibility with all systems... I often have to share files between different OSes (Windows, Mac and Linux) and non-standard characters in filenames can be a nightmare...
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
shortyzpapa815
I'm having the same problem with two seperate (.aup) files. "reference to invalid character number at line 7" and "reference to invalid character number at line 10". When I drag the project file into TextEdit, all that comes up is an Audacity icon - not the code. What am I doing wrong?
Open the AUP file using the File Open menu option.shortyzpapa815 wrote:When I drag the project file into TextEdit, all that comes up is an Audacity icon - not the code. What am I doing wrong?
shortyzpapa815
This is the first one:
<?xml version="1.0" standalone="no" ?>
<!DOCTYPE project PUBLIC "-//audacityproject-1.3.0//DTD//EN" "http://audacityteam.org/xml/audacityproject-1.3.0.dtd" >
<project xmlns="http://audacityteam.org/xml/" projname="untitled 2 : 10 Healing Ceremony 1_data" version="1.3.0" audacityversion="1.3.12-beta" sel0="0.0000000000" sel1="0.0000000000" vpos="0" h="0.0000000000" zoom="1.3373143726" rate="44100">
<tags>
<tag name="id3v2" value="0"/>
<tag name="GENRE" value="Noise"/>
<tag name="ARTIST" value="Musicians of Malaysia"/>
<tag name="TRACKNUMBER" value="2"/>
<tag name="TITLE" value="Titel 02"/>
<tag name="Full Name" value="Healing Ceremony"/>
<tag name="ALBUM" value="Dream Songs and Healing Sounds in the Rainforests of Malaysia"/>
</tags>
<wavetrack name="untitled 2 1" channel="0" linked="1" mute="0" solo="0" height="150" minimized="0" rate="44100" gain="0.501187" pan="0">
<waveclip offset="0.00000000">
<sequence maxsamples="262144" sampleformat="262159" numsamples="29106084">
<waveblock start="0">
<simpleblockfile filename="e00042bf.au" len="262144" min="-0.777256" max="0.748909" rms="0.419688"/>
</waveblock>
<waveblock start="262144">
<simpleblockfile filename="e0004183.au" len="262144" min="-0.742214" max="0.736741" rms="0.398895"/>
</waveblock>
<waveblock start="524288">
<simpleblockfile filename="e0003ce7.au" len="262144" min="-0.804666" max="0.812721" rms="0.426377"/>
</waveblock>
<waveblock start="786432">
<simpleblockfile filename="e0003ab7.au" len="262144" min="-0.775908" max="0.768544" rms="0.429719"/>
And this the second:
<project xmlns="http://audacityteam.org/xml/" projname="usa live performance #1 23-11-93 1:18 Healing Ceremony 1_data" version="1.3.0" audacityversion="1.3.12-beta" sel0="102.5500000000" sel1="102.5500000000" vpos="0" h="0.0000000000" zoom="2.4768401656" rate="44100">
<tags>
<tag name="id3v2" value="1"/>
</tags>
<wavetrack name="usa live performance #1 23-11-93 1" channel="0" linked="1" mute="0" solo="0" height="150" minimized="0" rate="44100" gain="0.794328" pan="0">
<sequence maxsamples="262144" sampleformat="262159" numsamples="17104896">
<simpleblockfile filename="e0001c34.au" len="262144" min="-0.489205" max="0.421064" rms="0.111405"/>
</waveblock>
<simpleblockfile filename="e00010bf.au" len="262144" min="-0.420284" max="0.348282" rms="0.101315"/>
</waveblock>
<tags>
</tags>
</waveblock>
</waveblock>
</waveblock>
<tags>
</tags>
</waveblock>
</waveblock>
- Quality Assurance
So in the first project, please remove "" from <tag name="Full Name" value="Healing Ceremony"/> so that it reads:
And from the second project, remove the "" from <tag name="Full Name" value="Healing Ceremony"/> so that it reads:
If you need to distinguish the files in the tag just call them "Healing Ceremony 1", Healing Ceremony 3" or whatever. If you don't care, just delete those lines. Save the file without changing the extension. Audacity should now be able to open it.
Make sure you upgrade to 1.3.13 which has a fix for this problem. If you import the files into 1.3.12 you will have the same issue again.
Code: Select all
Code: Select all
shortyzpapa815
Alright, did that and upgraded to the newer beta...but now I get an "error: not well-formed (invalid token) at line 8 and 10" respectively, for both of them.
- Quality Assurance
Please upload both .aup files using "Upload attachment" underneath the buttons where you write your posts.shortyzpapa815 wrote:Alright, did that and upgraded to the newer beta...but now I get an "error: not well-formed (invalid token) at line 8 and 10" respectively, for both of them.
shortyzpapa815
Here they are
- Attachments
- usa live performance 1 23-11-93 - 18 Healing Ceremony 1.aup
- (33.17 KiB) Downloaded 81 times
- untitled 2 - 10 Healing Ceremony 1.aup
- (53.48 KiB) Downloaded 84 times
- Quality Assurance
Try the attached edited projects. In both cases you had:shortyzpapa815 wrote:Here they are
Code: Select all
<tag name="Full Name" value="Healing Ceremony/>
Code: Select all
Code: Select all
<wavetrack name="usa live performance #23-11-93 1" <snip>
- Attachments
- (53.48 KiB) Downloaded 103 times
- (33.16 KiB) Downloaded 74 times
