What do those Effects do?
judaskiss
Post by judaskiss » Mon Apr 07, 2008 7:16 pm
Okay, two things, I just downloaded some more plug-ins to see what kind of sounds I could get. There are alot and I don't know, not being on non-musician side of the board, what majority of them do. Is there a description of what common uses are for these effects? Second, how do you get what you are putting an effect on to play so you can hear what you are doing as you adjust the effect? Hope that makes sense.
If its too loud, you're too old--young at heart
Locopomo
Re: What do those Effects do?
Post by Locopomo » Mon Apr 07, 2008 9:22 pm
I don't know if there's a specific description of each effect anywhere in the Audacity documentation, but I would suggest you Google each effect title in turn - I'm sure you would get a wealth of generic information about what each effect does.
As for using effects in real time as you describe, unfortunately this is something Audacity can't do. You have to apply an effect then play it back to hear the result. In addition Audacity can't display the custom user interfaces provided with most VST plugins.
