Can't reassign loop play
jonahhh
Post by jonahhh » Tue Sep 07, 2010 6:49 pm
I tried to set it up so that loop play was space and shift+space was play, but it doesn't work. In the transport menu it says loop play is space, but space just plays once though. Is this a known bug?
billw58
Re: Can't reassign loop play
Post by billw58 » Tue Sep 07, 2010 7:52 pm
Right you are. It appears that one cannot assign <space> to anything other than Play. This may have to do with the fact that <space> Plays when stopped and Stops when playing. You can assign "L" to loop play, if that helps.
Tested with 1.3.12 Mac OS X 10.4.11 PPC.
-- Bill
Post by steve » Tue Sep 07, 2010 9:10 pm
You can assign Space to Loop Play if you first assign "Play/Stop" to an unused key.
Note that "Play/Stop" is not "Play" and "Stop". You will find "Play/Stop" in the "Commands" category.
Setting Space to Loop Play will not allow you to stop the Loop Play with the Space - you will still need to use the Play/Stop key to make it stop.
billw58
Post by billw58 » Tue Sep 07, 2010 9:43 pm
stevethefiddle wrote:You can assign Space to Loop Play if you first assign "Play/Stop" to an unused key.
I stand corrected.
-- Bill
