Audacity won't launch on Indamixx, Linux Ubuntu
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
cherieo
Post by cherieo » Tue Sep 07, 2010 4:20 am
Audacity won't launch on new Indamixx Netbook, Linux Ubuntu. Don't know what versions. Indamixx just updated/upgraded to their latest OS version with a script.
Seems like some sort of conflict.
Audacity used to launch at least, although I had not tried much more than a 10 second recording and it would get stuck/stop recording.
How can I try running it from the terminal command line? I don't know much about Linux commands.
Are there typical things I could check like software version from the command line?
thx,
Cherie O.
Re: Audacity won't launch on Indamixx, Linux Ubuntu
Post by steve » Tue Sep 07, 2010 7:25 am
cherieo wrote:How can I try running it from the terminal command line?
Type: audacity
You would probably be best to contact indamixx re. the other questions. They will know what they've done, but we don't.
