I have some question and answer discs and tapes which have excessive separation. The question is almost entirely from one speaker or earphone and the answer from the other side.
I have an assymetric hearing loss, but still have binaural hearing. The poorer ear helps the other, but when I try to listen to these stereo recordings I can either hear the answer well or the question well. I need a monaural track so that both the question and answer are intelligible to me.
I have tried to combine or mix the stereo tracks so that both the questions and answers have the same amplification and sound quality, but cannot do so. I have tried the quick mix function, but that doesn't seem to function. No matter what I try the "Mono" is grayed out on the Mix bar. I just cannot combine the two tracks. I have gone repeatedly to the FAQ and the Help area as well, but know that there must be a very simple solution.
How to combine stereo tracks for a monaural recordings
straightupwv
Re: How to combine stereo tracks for a monaural recordings
Before you can select the"Mono" option, you need to select "Split Stereo Track". Then select "Mono" on both tracks. Export as either a WAV or MP3 and your resulting track will be in mono.
Time flies like an arrow. Fruit flies like bananas.
thank you very much. your instructions were great. it does exactly what i have been trying to do.
too bad i spent so much time trying to find out how to do it from the FAQ and Help.
straightupwv
You're welcome! I guess that question hasen't been asked enough to be classified as Frequently Asked.
