Auto Gain?
redlemon
Re: Auto Gain?
Post by redlemon » Fri Sep 10, 2010 8:50 am
i didn't replay it in itunes, only VLC.
i think i'll just do without that music file (and audacity) :(
Re: Auto Gain?
Post by steve » Fri Sep 10, 2010 10:05 am
It could be very useful if you could hang on with this for a while. We have never seen this problem before (out of millions of users), and if we establish that it is due to a bug in Audacity then it needs to be fixed. As you are the only person that we know that has found this problem, you are the only person that can help us to find out if it is an Audacity bug. If it is not due to a bug in Audacity, then it would still be very valuable to us if we could track down the cause of the problem - 1) because the problem can probably be fixed and you would then be able to use Audacity, and 2) we could then be able to advise anyone else that has the problem.
redlemon wrote:i tried importing/exporting the piano file from audacity:
a very noticeable increase in volume, and possibly an increase of resonance as notes, particularly the last one, decayed.
but certainly not like the file i was originally working with.
Could you upload the exported version to the forum. By comparing it with the original file we may get some idea of what's going on here.
Re: Auto Gain?
Post by kozikowski » Fri Sep 10, 2010 8:24 pm
You're a celebrity. Blank looks from two continents. <g>
Re: Auto Gain?
Post by steve » Sun Sep 12, 2010 2:03 pm
redlemon wrote: just redone the piano file with audicity, and the difference is not so great as i thought at first, now that i've played around with it.
i think it might be more informative to send you the original track which is fairly lo-fi rendition of stairway to heaven, cropped from bbc iplayer.
actually, it's a big file, so i can zip it and host it somewhere.
let me know if you want a listen.
It would be more useful to have a "before and after" of a known good file. This is why we suggested importing then exporting the piano.wav file. If you export in wav format it should be virtually identical to the original. When exporting in a compressed audio format (such as MP3 or OGG) then it is normal for their to be some difference.
redlemon
Re: Auto Gain?
Post by redlemon » Mon Sep 13, 2010 4:10 pm
i redid the piano file, re listened, and found it is "virtually identical" to the original. that is not at all the case with the troublesome file in my original question.
Re: Auto Gain?
Post by steve » Mon Sep 13, 2010 4:39 pm
redlemon wrote:that is not at all the case with the troublesome file in my original question.
have you tried again with the troublesome file? If not, open Audacity, import the file, but before you export as WAV, look in the "Project Rate" box in the lower left corner of Audacity. Set this to 44100 if it is not already set at that, then Export as 16 bit WAV.
redlemon
Re: Auto Gain?
Post by redlemon » Tue Sep 14, 2010 9:58 am
stevethefiddle wrote: have you tried again with the troublesome file? If not, open Audacity, import the file, but before you export as WAV, look in the "Project Rate" box in the lower left corner of Audacity. Set this to 44100 if it is not already set at that, then Export as 16 bit WAV.
it's 44100. dunno how to set it to 16 bit, it's just on defaults.
screen of original file:
screen of exported/reimported WAV file:
billw58
Re: Auto Gain?
Post by billw58 » Tue Sep 14, 2010 2:16 pm
From the screenshots it is apparent that you are using Audacity 1.2.x. Upgrade to 1.3.12 http://audacityteam.org/download/beta_mac and see if your problems go away.
-- Bill
redlemon
Re: Auto Gain?
Post by redlemon » Tue Sep 14, 2010 6:45 pm
billw58 wrote:From the screenshots it is apparent that you are using Audacity 1.2.x. Upgrade to 1.3.12 http://audacityteam.org/download/beta_mac and see if your problems go away.
-- Bill
Export is greyed out in the new version.
edit: ok, it's mysteriously allowing me to export now.
result: much the same. maybe not so pronounced.
thanks for the help, but it's not that important to me, and i've lost interest now. life's too short etc.
thanks again.
billw58
Re: Auto Gain?
Post by billw58 » Tue Sep 14, 2010 6:48 pm
redlemon wrote: Export is greyed out in the new version.
Export will be greyed out if there is nothing to export. Import or record a file and try again.
-- Bill
