Recording input - "stereo mix" now gone
Re: Recording input - "stereo mix" now gone
Post by steve » Sun Sep 12, 2010 4:08 pm
Asterus wrote:then my computer suddenly lost stereo mix again. I realized that happened only after windows update ran and picked something up.
Windows Update has updated the drivers to a version that does not support Stereo Mix (thank you so muck Microsoft).
If you are using drivers that are specific for your sound card/mother board, then you should not get this problem. It will generally only occur if you are using the generic Windows drivers. (Windows should not attempt to automatically update any drivers other than those which are supplied as a part of the Windows operating system).
