"Failed to load Device on Disk" Message after Loading
thedr
Post by thedr » Fri Sep 03, 2010 6:19 am
Hi,
I just installed and sync'd my VST plugins, and towards the end I get a message: "Failed to load Device on Disk".
Now I get this message every time I launch Audacity.
Does anyone know what this means?
Thanks.
Re: "Failed to load Device on Disk" Message after Loading
Post by steve » Fri Sep 03, 2010 12:21 pm
My guess is that it's a message from one of your VST plug-in.
Does Audacity open after that message, or can you not open Audacity?
thedr
Post by thedr » Fri Sep 03, 2010 9:28 pm
Thanks for your reply. Yeah it seems to open fine. At first I thought all of the options were disabled, but I think it's fine. Is there a place where I can disable VST's or manage which ones are enabled or disabled?
Post by steve » Sat Sep 04, 2010 4:14 pm
You can disable all VST effects in "Edit menu > Preferences > Effects".
Try disabling VST completely - if that solves the problem but you want to be able to use the VST effects that are compatible, then it's a matter of temporarily moving all of the VST effects so that Audacity does not see them, then putting them back one at a time 'till you find the one(s) that cause a problem. Each time that you add a VST you will need to tell Audacity to rescan for VST effects so that Audacity will look for new ones.
