Noise Reduction vs. Noise Removal
rorser
Post by rorser » Sat Aug 28, 2010 1:00 am
The tutorial shows: Click Effect > Noise Reduction
But, the beta has Noise Removal. Are they one and the same?
R
Richard
Santa Cruz, California
Re: Noise Reduction vs. Noise Removal
Post by steve » Sat Aug 28, 2010 1:21 am
rorser wrote:The tutorial shows: Click Effect > Noise Reduction
I think it should say "Noise Removal".
If it's an on-line tutorial could you post a link and I'll check it out.
ignatz
Post by ignatz » Sat Aug 28, 2010 1:25 am
I haven't looked at the tutorial---it may not have been rewritten from an earlier version.
I'd guess they are the same.
"Noise Reduction" is not among the effect choices in 1.3.12. Probably just a rename.
You get the noise profile from a near silent portion of the song by grabbing it with the mouse. Then you go back and select the entire song. Then you apply the effect.
If that describes what you are seeing in the tutorial, then it looks like 2 names for the same thing.
Post by steve » Sat Aug 28, 2010 1:50 am
This tutorial refers to it as Noise Removal http://wiki.audacityteam.org/wiki/Noise_Removal
waxcylinder
Post by waxcylinder » Sat Aug 28, 2010 9:47 am
And this titorial from the 1.3/2.0 manual also refers to it as noise removal - see: http://manual.audacityteam.org/index.ph ... _Exporting
rorser
Post by rorser » Sat Aug 28, 2010 11:37 pm
file:///C:/Program%20Files%20%28x86%29/Audacity%201.3%20Beta%20%28Unicode%29/help/manual/noise_removal.html
This is the link that shows when I am using Firefox to view the tutorial.
Richard
waxcylinder
Post by waxcylinder » Sun Aug 29, 2010 10:30 am
Richard,
it looks like you are referencing a copy of the manual which is located on your PC (hence the C: drive in the "link").
I presume you are accessing it from the help, right? IIRC you can set your Audacity either to get online/web-based "Help" or to access "Help" on your PC (the latter option is normally for folk who need to work offline). If so then it will be "frozen" from the time you downloaded te help library - and will not be being updated.
You are much better off using the online manual as that is updated fairly regularly - see: http://manual.audacityteam.org/index.ph ... =Main_Page
rorser
Post by rorser » Sun Aug 29, 2010 6:13 pm
Yes, that is correct. I will certainly use the on-line help in the future.
Thanks,
R
Richard
