Export Multiple not exporting music, only labels...
mpcain
Post by mpcain » Thu Aug 26, 2010 8:07 pm
I have labeled 15 songs in a 2 hour long Audacity audio file using 1.3.11-beta (Unicode) on OX 10.6.4. When I use the "Export Multiple" command to export the songs as AIFFs to a folder from which I hope to import them into iTunes, they export quickly but, no matter what settings I choose, have durations of 0 and are all only 4kb in size. It seems that the labels are being exported but not the music associated with each label. What can I do to get the music to export????
Re: Export Multiple not exporting music, only labels...
Post by Gale Andrews » Thu Aug 26, 2010 10:20 pm
Are you receiving any error messages such as "cannot export audio"? Don't use the / character in the labels.
If that isn't the issue, are these labels at a point or a selection region, and can you post an image of the Export Multiple dialogue? If your export format in that dialogue is "Other uncompressed files", click the Options button in the dialogue and tell us what Header and Encoding you are using.
