Exporting from Audacity
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
theseus75
Post by theseus75 » Thu Aug 26, 2010 2:09 am
This is similar to another post I just made, but dissimilar enough to warrant another thread methinks.
I'm wondering if I record in Audacity, export to, say, mp3, and then edit in another application from which I'll have to export again, is that all going to result in a loss of quality? I know that when you edit a .jpg over and over you lose a little after a while, so I'm not sure if loss would be the result here for the same reason.
I suppose, that being the case, I could simply export in a lossless format, but it would be good to know anyway.
Thanks.
Re: Exporting from Audacity
Post by steve » Thu Aug 26, 2010 2:18 am
You are correct. Stick with lossless formats or you'll be loosing a bit of sound quality every time.
theseus75
Post by theseus75 » Fri Aug 27, 2010 12:50 pm
Okay, so it sounds like I can export from Audacity as lossless, do something like add effects in another app, and then export to whatever format without suffering a loss. Good to know.
