select and delete audio between labels
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
Edgar
Forum Crew
Post by Edgar » Wed Aug 25, 2010 9:48 pm
Is there an easy way to select the audio between a pair of labels, delete the audio and one of the labels?
-Edgar
running Audacity personally customized 2.0.6 daily in a professional audio studio
occasionally using current Audacity alpha for testing and support situations
64-bit Windows Pro 10
Re: select and delete audio between labels
Post by steve » Wed Aug 25, 2010 9:58 pm
Could you be more specific. Do you mean "point" labels (markers) or "region" labels? Do you need to do it entirely through the keyboard or with a mouse? What exactly are you wanting to do?
Edgar
Forum Crew
Post by Edgar » Wed Aug 25, 2010 10:10 pm
stevethefiddle wrote:Could you be more specific. Do you mean "point" labels (markers) or "region" labels? Do you need to do it entirely through the keyboard or with a mouse? What exactly are you wanting to do?
I mean "point" labels (markers). I need to do it through the keyboard after using the mouse to click somewhere in the wave or label track between the "point" labels.
I have used Silence Finder to split up a large file; I wish to remove some of the audio before doing an Export Multiple.
-Edgar
Post by steve » Wed Aug 25, 2010 10:40 pm
I don't think that you can do the entire operation through the keyboard when using point labels.
Probably the best that you can do is to select the label track, (Click on label track then SHIFT+HOME then SHIFT+END)
then Alt+I to split at the markers.
Deleting sections would then need the mouse to double click between to split points to select the region and it could then be deleted.
If you were using region labels, then you would be able to either delete the labelled regions, or keep the labelled regions and delete the rest.
