How To Work With Velocity In Audacity ???
musicmad
Post by musicmad » Wed Aug 25, 2010 1:04 am
Hi
Just installed Audacity 1.3.12 on a Mac OS-X 10.5. I'm looking to modify Audio Files that were recorded directly from a Yamaha P-120 digital piano in to an MD Recorder, this was way before i new anything about MIDI and the audio files recorded were then set in concrete, now with Audacity i hope to change that?
I'm basically looking to modify velocity levels on some Audio files, is it possible to do this in Audacity? :?
Re: How To Work With Velocity In Audacity ???
Post by steve » Wed Aug 25, 2010 1:39 am
Unfortunately not - it's been set in concrete. Neither Audacity nor any other audio editor can change that.
What you can do is to change the volume dynamics and tone by applying various effects, but "velocity" is a property of the MIDI data that changes the sound that is created by the synthesizer for each individual note. Trying to modify individual notes after the even would be a very long and arduous job. If you had recorded the MIDI data into a sequencer, then you would have been able to edit the note velocities and re-recorded the new audio, but without a MIDI file you can't.
musicmad
Post by musicmad » Thu Aug 26, 2010 12:11 am
Thats exactly what i meant Steve, to change the volume dynamics and tone by applying various effects, not to change actual notes as i know only MIDI technology can perform this. I'm new to Audacity, to execute this feature should i be looking under the effects tab? :?
Post by steve » Thu Aug 26, 2010 12:34 am
A good place to start would probably be the Envelope Tool: http://manual.audacityteam.org/index.ph ... elope_Tool
musicmad
Post by musicmad » Thu Aug 26, 2010 10:16 am
Thanks for your support Steve, will take it from there. :)
Mm.
