Exporting "malfuncton"
John B
Post by John B » Thu Aug 19, 2010 11:20 pm
Can't export properly! Using OS 10.6.4. Recorded 25 (3min) tracks (@44100) from LP's using pause button, then labeling each. Looks OK, so far. Then, selecting "AIFF" (Apple) signed 16 bit PCM (also tried .wav) & "File - Export Multiple", I was unsuccessful exporting to iTunes (doc folder), desktop, or folder on desktop. In iTunes a 1hr 15min continuous file arrived without labels or individual tracks. On the export to desktop try, only the 1st track showed up. Audacity displayed an error message: "Cannot export audio to /Users/JB/Desktop/30's-40's music/etc...aiff" and also this message: "Export canceled after exporting the following 1 file(s): (1st file named)". Had no trouble with Audacity 1.2.5 last year, but can't seem to conquer this beta. Any suggestions appreciated. John
Re: Exporting "malfuncton"
Post by Gale Andrews » Fri Aug 20, 2010 1:05 am
Export doesn't include labels, it only splits at labels into separate files. AIFF will include metadata if you enter any when exporting.
Do any of the labels include the / character? If so, removing it may cure the problem.
waxcylinder
Post by waxcylinder » Fri Aug 20, 2010 9:47 am
You might find this tutorial workflow useful: http://manual.audacityteam.org/index.ph ... _to_iTunes
John B
Post by John B » Fri Aug 20, 2010 3:40 pm
Gale - Yup, I was using /'s in my labels! Fixed everything this AM. Thanks so much for your thoughts. You are the greatest! Regards, John
