Hello
I have Audacity 1.3.4 Beta installed on 8 networked hosts (OS is Windows XP Pro). The net has a lot of users, and all users can work in all hosts.
Audacity writes a user configuration folder in her/his profile, C:Documents and SettingsuserApplication DataAudacity. Everything works fine, but this config file is only for a computer.
The question is: Can I change the user config folder from %userprofile%Application DataAudacity to other directory?
In particular, I would change the user config folder to a network drive (H:userAudacity or something like this).
Thanks in advance
Users config file with several computers
