Channels going in and out
pinballwizard96
Post by pinballwizard96 » Thu Aug 19, 2010 1:30 am
When recording using Audacity, I notice when playing back a song, during random points a pop will occur and one channel goes out. This only lasts a second or two and happens once per song (if at all). Upon listening to the affected songs (on the LP album that I was recording), the audio was fine. Any idea what is causing this?
"I have terrible hearing trouble. I have unwittingly helped to invent and refine a type of music that makes its principal proponents deaf." - Pete Townshend
Re: Channels going in and out
Post by kozikowski » Thu Aug 19, 2010 2:08 am
If you play that portion of the song again and again, does the pop happen in the same place -- at the same note?
If you drag-select and magnify (Control-E) the blue waves around the place of the pop, is there is missing piece in the waves?
pinballwizard96
Post by pinballwizard96 » Thu Aug 19, 2010 3:00 am
Yes - it is at the same spot. Note that this is only happening after I export the song; no problems are visible or audible before the export. Attached is a shot of what it looks like when I open an affected file.
When I export, I am saving as signed 32-bit pcm WAV @44.100 kHz.
