sry about my last post, im actually using the beta
iliketoeatpie
Post by iliketoeatpie » Sat Aug 14, 2010 2:23 am
hey guys, I just finished doing a commentary for a call of duty video for the first time, and i have a question. I am on mac, but i will be transfering the file onto my pc....is that possible? if it is, once i have it on my pc, how do i put the audio track into sony vegas? thanks
billw58
Re: sry about my last post, im actually using the beta
Post by billw58 » Sat Aug 14, 2010 3:23 am
Audacity projects are portable between operating systems. Also, if you export as a WAV file, your PC will be able to read it. As for "sony vegas" I have no idea.
-- Bill
iliketoeatpie
Post by iliketoeatpie » Sat Aug 14, 2010 4:33 am
But it only lets me save as an audicity file.
Post by kozikowski » Sat Aug 14, 2010 6:03 am
That's correct. Audacity will not Save a sound file. File > Export.
bgravato
Post by bgravato » Thu Aug 19, 2010 12:35 am
To "save" in other formats, like koz said, is done by "exporting".
To copy an audacity project (saved in the audacity format) you have to copy not only the .aup file but also the data folder with the same name (and with a ton of weird names files in it).
Also avoid using non-alphanumeric chars in the file name. Avoid characters like '@', '#', 'á', or even spaces. Underscores ('_') and hyphens ('-') are ok.
This is because different operating systems often use different codepages and that will most likely cause problems when copying and opening file names containing non-alphanumeric chars, which are coded differently in different codepages.
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
