Audacity just wont open :(
fleshcravingsuperman
Post by fleshcravingsuperman » Fri Mar 28, 2008 1:38 am
i have been happily using audacity for a couple of days, i just finished mixing a few tracks when i tried opening another audacity and it seems to have crashed or something, but now (even after restart & shutdown) it comes up in task manager and toolbar but will not show up on screen, i have tried opening audacity files, that doesn't work either
im on vista 32bit home basic (if that helps)
just before, i exported a 3 min file into vbr mp3 has this got anything to do with it?
thanks
Re: Audacity just wont open :(
Post by steve » Fri Mar 28, 2008 5:27 pm
Try deleting the Audacity temporary folder and the Audacity Configuration file. This should reset Audacity.
The default location for the temporary files folder is in; Documents and Settings<user name>Local SettingsTemp
The default location of the configuration file (audacity 1.3.x) is; Documents and Settings<user name>Application DataAudacityaudacity.cfg
