Is there a way to center the "cursor location" in the window
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
Edgar
Forum Crew
Post by Edgar » Thu Aug 12, 2010 3:06 pm
Lots of times I will start playing and the current "cursor location" will scroll off-screen. Often I am zoomed in a fair amount and finding the "cursor location" again is tedious. I now hit the spacebar three times quickly--stop, start, stop (immediately) which usually does the job but has drawbacks. Is there a keyboard shortcut (or command to which a shortcut may be applied) which (when stopped) will do this?
-Edgar
running Audacity personally customized 2.0.6 daily in a professional audio studio
occasionally using current Audacity alpha for testing and support situations
64-bit Windows Pro 10
Re: Is there a way to center the "cursor location" in the wi
Post by kozikowski » Thu Aug 12, 2010 4:57 pm
Audacity Preferences > Tracks > [X] Update Display while Playing.
This drives me crazy because I never know where the display has snapped to, and I apparently lose my edit point.
billw58
Post by billw58 » Thu Aug 12, 2010 5:52 pm
CTRL+F to "Zoom to Fit in Window" then CTRL+1 repeatedly to zoom in on the cursor location.
-- Bill
Edgar
Forum Crew
Post by Edgar » Fri Aug 13, 2010 3:33 pm
kozikowski wrote:Audacity Preferences > Tracks > [X] Update Display while Playing.
I actually want the display to scroll with playing--wish there was a way to keep the current playing sample centered.
billw58 wrote:CTRL+F to "Zoom to Fit in Window" then CTRL+1 repeatedly to zoom in on the cursor location.
-- Bill
This might help--I had not noticed that "Fit In Window" followed by CTRL+1 zoomed on the Cursor. I think I can store a variable of "preferred working zoom" and create a voice-activated script which does "fit in window" followed by an appropriate sequence of ctrl+1.
-Edgar
Post by steve » Sun Aug 15, 2010 1:48 pm
Edgar wrote:I actually want the display to scroll with playing--wish there was a way to keep the current playing sample centered.
<< Smoother Track scrolling on Playback: Keep the cursor in one place but move the track - gives smooth visual playback without continual cursor back and forth (10 votes) >>
I've added your vote here: http://wiki.audacityteam.org/wiki/Featu ... ifications
Edgar
Forum Crew
Post by Edgar » Sun Aug 15, 2010 2:22 pm
stevethefiddle wrote: << Smoother Track scrolling on Playback... >>
Thanks!
-Edgar
