Exporting files
keen
Exporting files
Post by keen » Tue Aug 10, 2010 11:09 am
Hi
How do I export 32 bit wav files from 1.3x beta?
Also, how would I export MP3 variable bitrate files?
Thanks
waxcylinder
Re: Exporting files
Post by waxcylinder » Tue Aug 10, 2010 11:38 am
For 32-bit WAVs - in the Export dialog box, see the dropdown selector labelled "Save as type" and select "Other uncompressed files". Then click on the Options button and in that dialog box select WAV and 32-bit.
For VBR MP3s - in the Export dialog box, also see the dropdown selector labelled "Save as type" and select "MP3". Then click on the Options button and in that dialog box set the VBR radio button on.
If you don't change anything in the meantime Audacity will remember these settings for you (and IIRC it maintains seperate settings for Export and Export Multiple)
keen
Re: Exporting files
Post by keen » Tue Aug 10, 2010 11:46 am
Excellent. Missed that 'options' box.
Thanks for rapid response; can now get on with the project.
