faster PlayAtSpeed
Edgar
Forum Crew
faster PlayAtSpeed
Post by Edgar » Mon Aug 09, 2010 5:50 pm
Currently the transcription toolbar function PlayAtSpeed has a maximum value of 3X. My editing deck allows much higher multiples, I am used to searching raw data for "non-music" (speech etc.) and can recognize the difference at speeds between 7X and 10X.
If we look at the source code, AudacitySVNsrcwidgetsASlider.cpp, at or near line number 399:
Code: Select all
   case SPEED_SLIDER:
      minValue = 0.01f;
      //maxValue = 3.0f;
      maxValue = 20.0f;
      stepValue = STEP_CONTINUOUS;
      break;
We see that changing maxValue from 3 to 20 seems to do the trick. I tested this and it seems to work just fine although speeds above 10X appear to be useless for my purposes.
-Edgar
running Audacity personally customized 2.0.6 daily in a professional audio studio
occasionally using current Audacity alpha for testing and support situations
64-bit Windows Pro 10
waxcylinder
Re: faster PlayAtSpeed
Post by waxcylinder » Tue Sep 07, 2010 3:51 pm
Posting moved to Audio processing to retain the code - gist moved to Pending FRs on the Wiki
