How do you install VST plugins?
chillowack
Post by chillowack » Mon Aug 09, 2010 1:06 am
I've downloaded some Kjaerhus VST plug-in effects, but when I open Audacity, I don't see them on the "Effects" list.
I can see the plug-ins in the Audacity plug-ins folder, but I don't see them appearing in Audacity itself.
What is the process for installing VST plug-ins?
Thanks.
Re: How do you install VST plugins?
Post by Gale Andrews » Mon Aug 09, 2010 5:22 am
chillowack wrote:I've downloaded some Kjaerhus VST plug-in effects, but when I open Audacity, I don't see them on the "Effects" list.
You probably just need to restart Audacity as explained on this Wiki page.
chillowack
Post by chillowack » Tue Aug 10, 2010 5:31 pm
Nope, that didn't work.
Any other ideas?
Post by Gale Andrews » Tue Aug 10, 2010 8:31 pm
Read the Wiki VST Plug-ins page again. Have you installed the VST Enabler?
Where are you looking? The plug-ins should be in the Effect menu underneath the divider.
Or use Beta 1.3.12 which doesn't need the VST Enabler.
chillowack
Post by chillowack » Tue Aug 31, 2010 3:23 pm
Okay, I figured this out.
Turns out I needed to go to Preferences and check "Rescan VST effects next time Audacity is started".
Thanks for your help!
