This is important so we can confirm bug fixes made are actually working OK on Mac.
- Bug 30: Unmodified Transport shortcuts write label at cursor position Seems OK on Mac but fix mostly doesn't work on Windows so will need testing again when Windows is fixed.
- 170: Sliding Time Scale segfault applying extreme settings with sharpening Tested OK with current code, will need a short re-test when the fix for 48000 Hz and higher problems is committed.
- 177: Unwanted label appears if pasting audio when there are already labels -
There have been lots of changes to Paste, so we need to test pasting into single and multiple tracks, with and without label tracks, and with and without linking enabled - 196: History window is slow to populate Tests completed OK.
To test, please view the Release Notes or Steps to Reproduce in the bug.
If you have a Bugzilla account please post comments in the bug, otherwise here. Anyone who would like a Bugzilla account, please ask.
Your help would be much appreciated.
Thanks
