Importance of Recording Levels for 16-Bit?
I'm going to be recording some vinyl LPs using a 16-bit USB audio interface (it does have a knob controlling the level that enters its ADC). Apart from noise concerns, is it true that recording at a higher level will give a more accurate recording than at a lower level? The example below made me think so:
-- Will use 16 bit in the example: 16 bit has 2^16 baskets of amplitude = 65536, which covers -1 to 0 to +1 on the Audacity linear scale. For simplicity consider only the positive part of the signal, which is covered by half that number, so 32768 baskets of amplitude.
-- The example: an analog signal with a positive peak at +0.3 on the linear scale (assume negative peak -0.3), being converted to digital with 16 bits would be documented by 0.3*32768 = 9830 baskets of amplitude. However if that analog signal were first amplified to peak at +0.9, then it would be documented by 0.9*32768 = 29491 baskets of amplitude. So it would seem that tripling the analog signal before entering the ADC would document the same wave with three times the baskets of amplitude, or three times the fineness.
I initially thought 9830 baskets still seemed like a large number, but then remembered reading that some of the very first CDs were digitized with 14 bits and often sounded bad. 14-bit has 2^14 = 16384 baskets of amplitude, with the positive part of the signal covered by half that number, so 8192, which is close to the lower-level 16-bit example of 9830.
So APART from noise concerns, is it true that recording at a higher level will :
1. Give a more accurate recording than a lower level?
2. With 16-bit, lower the risk of sounding poorly like the 14-bit CDs did?
(I know using 20, 24, or 32 bit would make these questions irrelevant, but I'm limited to 16. Also, I'm very interested in the answers for technical understanding.)
Thank you for sharing your expertise.
Re: Importance of Recording Levels for 16-Bit?
I'm going to side-step the question with the idea that you should always record a live performance as loud as you can with no possibility of overload damage. Overload or clipping is almost always fatal.
The limit of 16 bit recording is something like 90dB, which, given the converter can do it, gives you 20 dB overload headroom and 70dB noise floor. More than enough for non effects-heavy production.
Chances are, the electronics before the A to D converter are worse than that and the vinyl record will certainly be worse, the restriction on quality will not be the 16 bit spec.
If you're going to burn your vinyl to Music CD, the show is going to get converted into 44100, 16-bit, Stereo anyway.
- Quality Assurance
Chris, you followed up with me on your above questions in a PM.chris224 wrote: is it true that recording at a higher level will :
Probably Steve is the best person to go into details, but Koz is broadly correct that if you are recording vinyl the noise floor is likely to be above the -96 dB level anyway, and that if you had 24-bit recording capability (Audacity on Windows does not) the mere fact you were exporting to a 16-bit format would make the question fairly academic.
If you were recording 24-bit to a 24-bit format, it allows you to represent samples between -97 dB and -145 dB, the latter value being lower than most people can hear. 16-bit cannot represent those samples. 24-bit will give you smoother steps from one sample to another, but analogue playback smooths the more abrupt jumps in 16-bit anyway.
"Baskets of amplitude" is a strange term and I think it may be misleading you into thinking a 16-bit value at 0.331309 is inherently less accurate than one at 0.931309. I would see it that the lower level recording is equally accurate as a representation of the "noise and signal", but it's a less accurate representation of the possibilities afforded by the signal because the signal is smothered by the noise.
As for 14-bit/16-bit, yes 16-bit is more accurate than 14-bit in the same way 24-bit is more accurate than 16-bit.
I'm shutting up now because this isn't my area of expertise.
though I don't think there is much need - I think that Gale and Koz have covered the question thoroughly.Gale Andrews wrote:Probably Steve is the best person to go into details,
The only thing that I might add is that while 14 bit audio is not "audiophile" quality, it is not as bad as many people assume. Even a 12 bit recording (using the full 12 bits and assuming that the bit depth is the only limiting factor to the sound quality) sounds a lot better than what a lot of people listen to on their iPods. Uncompressed 14 bit audio is measurably better than an MP3 at 128 kbps. Audio does start to sound noticeably "rough" and noisy below 12 bit, which is why it is important to have a reasonable recording level. For recording from a source with a predictable peak level, (for example when transferring tape or vinyl to digital), a target peak level of around -6 dB is usually recommended (which works out as equivalent to 15 bit).
People often get "hung up" on the bit depth question, forgetting about other parts of the signal chain. For best quality recording it is important to keep as close as possible to an optimum level throughout the signal chain - so if recording with a microphone, that means using a microphone with low noise and suitable sensitivity for the sound, correct levels in the pre-amp stage (and a suitable pre-amp to match the microphone signal), the level through the mixing desk (if used), a sound card input that has a line level input level that is matched to the pre-amp/mixing desk output and finally the recording level in the computer/recorder. The recording level (hence number of bits available) is only one level in the chain, and as long as it is set to a reasonable level it is probably going to be a less significant limitation to sound quality than other parts of the signal chain.
Which gives you a very simple signal chain to work with. You have only one level to worry about. Put on a really loud record and set the volume level so that you are getting a peak level in Audacity of around -6 dB. You should then be able to go through your records without needing to adjust the level on the turntable. Note that the peak level for a 45 will not be the same as for an LP, so you may need to "re-calibrate" the setting when switching from 45 to 33 1/3.chris224 wrote:I'm going to be recording some vinyl LPs using a 16-bit USB audio interface (it does have a knob controlling the level that enters its ADC).
How does one reliably do that?stevethefiddle wrote:set the volume level so that you are getting a peak level in Audacity of around -6 dB.
I am accustomed to viewing the waveforms against the 0, .5, 1.0 scale immediately to the left of the waveform display, and then adjusting level up or down with the input level slider next to the microphone symbol.
That scale is not finely demarcated--from zero to 1.0 is about 1 vertical inch on my screen.
I normally try to get peaks to be above .5, maybe .8, but never 1.0.
Is that sufficient care/technique or should I be using some other tool/scale for level setting, such as the "mixer board" from the view menu, which I have studiously avoided so far? I have no idea what it does and haven't examined it. I notice it has a DB scale, unlike the standard scale to the left of the waveform.
Suppose I record with a level clearly "too low" or clearly "too high". If I then use normalize or amplify to alter the capture before export, will that adjust my poorly set levels to proper level, just as if I had set levels correctly to begin with--with no ill effects at all?
If that is so, why should I pay much attention to levels IF I can "correct" them after the fact (before export) with normalize, amplify, envelope tool, etc?
I come from analog land (low levels mean background hiss on playback, high levels mean clipping) where bad levels cannot be undone and I remain a bit unclear on how, if at all, a bad level can be corrected before export in digital land.
waxcylinder
ignatz,ignatz wrote: ... That scale is not finely demarcated--from zero to 1.0 is about 1 vertical inch on my screen.
you can resize the meters by clicking and dragging, this makes them much more useful I have mine as a pair stretched across the whole width of my Audacity window - and IIRC Koz has each meter stretched across his screen witdth. I also have mine set to dB rather than liner - I find that more useful. And with 1.3 the settings you make are "remembered" in your preferences, so the next time you fire up Audacity you will get those some settings for the meters.
When I record LPs (and indeed also FM off-air) I aim for a max level of around -6 dB. Unlike Steve's one-off setting suggestion, I recalibrate/reset for each LP. With experience you can learn to see from the vinyl groove patterns which are the louer/loudest parts of the recording.
Note that the -6db level can easily be exceeeded with a big click/scratch/crud on the record. Note that if that happens you can reset the peak-level in the recording meter by clicking in it.
After recording and editing my final processing step prior to multiple export is to Amplify (not Normalize) to -2 dB
OK, I see what you mean by resize, but I don't follow the "across the whole width of my Audacity window". Attached are 2 pictures. One is the view I have always used. The other is zoomed to an extent. I don't see how the zoomed is an improvement as you cannot see the peak.
Can you post a pic of what you mean?
How do you read "-6 DB" from a scale extending from 0 to 1?waxcylinder wrote:When I record LPs (and indeed also FM off-air) I aim for a max level of around -6 dB.
I once saw a Steve post that gave the correlation between the two, but I cannot find it.
Do you use the mixer board, where you can read in DB directly?
Can you comment on my other points in my post--mainly about altering level AFTER capture with amplify or normalize. If that "works", why bother setting to -6 DB? Why not use any old level and then alter before export?
I'm clearly not understanding something here and need more clarity.
That's my practice also. I have transferred thousands of songs to analog tape over the last 40 years. I always set a new level every time something new landed on the turntable. I'm invariably familiar with the source and would just play maybe 15 seconds of it to adjust level, and then re-cue and start recording.waxcylinder wrote:Unlike Steve's one-off setting suggestion, I recalibrate/reset for each LP.
I'm aware that clicks or any unanticipated peak can push the level up, but am unclear on your second sentence. If I discovered something that drove levels too high, I would just move the input slider down a bit and don't follow what you are saying in that second sentence.waxcylinder wrote:Note that the -6db level can easily be exceeeded with a big click/scratch/crud on the record. Note that if that happens you can reset the peak-level in the recording meter by clicking in it.
- Attachments
- levels normal.jpg (104.89 KiB) Viewed 2708 times
- levels zoomed.jpg (81.25 KiB) Viewed 2706 times
Sorry - we've cross-posted here, so the topic has gone a little out of order.
The meter can be dragged with the mouse and stretched to full screen width which makes it easier to read accurately.
You can also set the display range for the meters in "Edit menu > Preferences > Interface". Setting it to a range of -96 dB is a good general purpose setting, but setting it to -60 dB will give you a bit more detail at the high end of the scale.
If you record at too high a level you will get distortion - the tops of the peaks will be clipped off flat. If the clipping is bad enough to be noticeable when you listen back to it, then it is probably too badly damaged to effectively repair. Clipping distortion is a show stopper - delete and record again.
If you record at too low a level, then you will not be taking full advantage of the available 16 bits from your sound card/audio device. This is less serious, but means that the base noise level will be higher than it should be. This effect starts to become noticeable if you are -12 to -24 dB below 0dB (depending on how "clean" the audio is that you are recording and how critically you are listening. A peak level of -6 dB is recommended because it allows a reasonable amount of headroom while keeping the noise floor close to minimum. For live (microphone) recording it is generally advisable to allow more headroom (say 12 dB) to allow for unpredictable peaks.
It is better to record too quiet than too loud but should be recorded at a reasonable level.
For USB devices on Win XP or Linux you would normally have the recording level set at maximum, then adjust the level of what you are recording (the turntable volume control). I'm not sure what you do on Vista or Win 7.ignatz wrote:How does one reliably do that?
Use the red recording meter http://manual.audacityteam.org/index.ph ... er_Toolbarignatz wrote:I am accustomed to viewing the waveforms against the 0, .5, 1.0 scale immediately to the left of the waveform display, and then adjusting level up or down with the input level slider next to the microphone symbol.
No. You can adjust the level of the recording, but it is not without ill effects.ignatz wrote:Suppose I record with a level clearly "too low" or clearly "too high". If I then use normalize or amplify to alter the capture before export, will that adjust my poorly set levels to proper level, just as if I had set levels correctly to begin with--with no ill effects at all?
There is absolutely no harm in doing that, though if using a USB turntable it may be more work than really necessary.waxcylinder wrote:When I record LPs (and indeed also FM off-air) I aim for a max level of around -6 dB. Unlike Steve's one-off setting suggestion, I recalibrate/reset for each LP.
The assumption in not recalibrating for each LP is that the audio level across multiple LPs is close enough to fit comfortably within a reasonable recording level range - that is with a peak level on the quietest LPs at least -12 dB, and the maximum peak level on the loudest LP still below 0 dB.
If you have LPs that lie outside of this range then you will need to recalibrate.
Question for you vinyl guys - does it matter if the click from a scratch is digitally clipped at 0 dB in your recording?waxcylinder wrote:Note that the -6db level can easily be exceeeded with a big click/scratch/crud on the record.
Steve:
Thanks for the comments.
In an inexplicable brain fade, my previous posts would have you believe I was unaware of the red meters. Not true, although I did not know they could be dragged screen wide.
Possible explanation for my brain fade:
In analog land (cassette/open reel/turntables/1977), levels are critical and I am all over those red meters in that situation.
But I have been led to believe that in digital land (Audacity/WAV/mp3), level settings are not nearly as critical.
Accordingly, I have been just setting levels roughly by eyeballing the wave form peaks against the 0 to 1 scale on the left--getting peaks above .5, but clearly, I say never, above 1. I pay some but minimal attention to the red meters and figure that if random song A has a different level than random song B, my playback volume control app (mp3 Gain) will iron it out reasonably well. I know from experience that equal levels on meters doesn't necessarily translate to equal playback "loudness".
Have I been led astray and are levels as critical here as on open reel/cassette??
At times, I will normalize or amplify after capture, but typically I DO NOT. My normal practice is to just capture at a reasonable level, export as mp3, and then use mp3 Gain to alter tags and thereby volume on playback.
Bad technique? Have I been misinformed about levels not being particularly important within reason?
