Code: Select all
Warning: Bloc de fichier orphelin : (C:Documents and Settingssons Inde1er montage''_datae00d00e0000062.au)If you send the log it would be easier if it was in English (click Edit > Preferences: Interface and change the language to English). To your questions:
Make a backup copy of the .aup then open the original in a text editor. You have at least eight folders "d01" to "d08" inside the "e00" folder in the _data folder. The fourth numeric character in the filename of the .au file (for example, 8 in e0008932.au) tells you that e0008932.au is in the "d08" folder (according to the .aup file). So if it was actually in the "d07" folder, moving it to the "d08" folder would restore it. I'm not saying that has happened but it could have done.thegrandwazoo wrote: How do I "check the aup to see where it suggests an .au file is" ?
If you have .auf files in the project, that means you imported a WAV or AIFF file into the project without copying that WAV/AIFF into the _data folder. Therefore the project depends for its audio on having that file available in the path you originally imported it from. The .aup file will give the path to the .auf file at "aliasfile=" to right of the name of each .auf file.thegrandwazoo wrote:I also come across a lot of .auf files
If you had made edits to that original audio but the aliasfile was missing, then the waveform would be silenced at that point. But you said the error log shows only orphans and missing data files, so I assume this isn't a problem.
Another thing you can do if you have a good text editor is to get it to count the number of instances of .au" in the .aup file. If you have the same number of .au files somewhere within the _data folder, then you just have to move them around until they are in the correct folders inside the _data folder.
Merci de noter que la plupart des membres de l'assistance d'Audacity ne parlent qu'anglais. Par conséquent, nous ne pouvons garantir une réponse aux questions en français.
