I am not sure what you mean. I thought the usual waiting time was 1 hour? Do you mean the recording timer dialogue was still open and it had so far recorded 5 hours? If so, what were the elapsed and remaining times in the "Audacity Timer Record Progress" dialogue?heseltine wrote:I started the usual recording yesterday (about 4 hours count-down with 2.5 hours recording time) but with out saving the project first. When I returned to examine the project, it had progressed to about 5 hours without the timer began to freeze on the 5th second. I killed the process using Task Manager. I then restarted Audacity and it began the crash recovery process. I allowed it to recover and saved the file. It seemed to work. I had to adjust the view of the tracks as they had compressed that into about 4 bars of one hour each - Zoom Normal fixed that.
Are you using 1.3.13? Please do so (that should respect track zoom level and position when you recover). 1.3.12 does not.
Same (if you are not using 1.3.13, please do so). That has some possible fixes to improve crash recovery (but as I explained before, saving if the program is not responding may always be problematical).heseltine wrote:Today, however, the same scenario happened - and the timer froze. I tried to click first on the X box in the upper right hand corner of the timer indicator box. Nothing. So I did the same with the "cancel" button on the timer indicator. Nothing. I then tried to kill the process using Task Manager but it said it was waiting for a response from me to an Audacity open dialogue box. That box asked whether I wanted to save the project before closing. I said yes. I pointed to a directory and I named the filename to save it with. It then began to save and opened a progress box showing the time elapsed. It froze after 5 seconds and stopped responding (with a label saying so in the upper left hand Audacity label area of the window frame. I think there was a dialogue box that said "close?" and I used Task manager to kill it instead. When I reopened Audacity no crash screen appeared. When I opened the project, only the last 1/5th of the project was saved. The first 3/5th of the track was blank.
Note that Cancel (and the red [X]) on the TImer Record Progress dialogue tells Audacity to discard what it has recorded - assuming Audacity was responding you would have to Edit > Undo to get the recording back. Pressing Stop (when Audacity is responding) stops and retains the recording.
