screech or whine or squeal thing
Re: screech or whine or squeal thing
Post by Gale Andrews » Fri Mar 08, 2013 9:51 pm
If you uncheck software playthrough the only disadvantage is that (as well as hearing no whine) you also won't be able to hear the recording through the computer speakers while you are making it.
The whine should not get recorded assuming you have the Audacity recording device correctly set to the USB Audio Codec.
You may also be able to listen to what the cassette player is sending to the computer (not necessarily exactly what gets recorded) by plugging headphones into the cassette deck.
