Stereo Mix refuses to record
Jinro
Post by Jinro » Wed Jul 21, 2010 4:57 am
Now....I've done this before less than a year ago on this exact machine (Samsung NC10 notebook, Windows XP), but now it won't work at all.
Yes, I have Stereo Mix selected from the drop down menu. Yes, I have Stereo Mix selected in my sound devices. Yes I have Realtek HD selected as input/output in Audacity. I play music, hit record, get a line flatter than a dead person. Yet it records fine from the mic.
I also tried the Freecorder plugin for Firefox/Internet Explorer, and even that couldn't find the audio playing....
I'm completely lost.
whomper
Probationer
Re: Stereo Mix refuses to record
Post by whomper » Wed Jul 21, 2010 3:31 pm
sounds like the audio isnt playing
or the volume got turned down
maybe its muted in realtek
can you hear anything through your speakers ?
not counting billygz noise with windoze
you should turn that off in your win options anyway
check the realtek mixer
enable *ALL* items so you can see them all
then make sure what you want to play is selected and the volume is max
then make sure you really have stereo mix enabled along with any other inputs you want and their volume is max
you may have to scroll left/right to do all of them
be sure anything you dont want is xed out muted and pull down the fader for the volume too
check that the record and playback mute is off as well as individual devices
now make sure you can play through your speakers
and try the recording again
after you select realtek in audacity
if it still fails tell us more about how you are doing this and one of the official honchos may be able to help
Jinro
Post by Jinro » Wed Jul 21, 2010 4:13 pm
Now this is strange....after I restarted my computer, it works fine.....
whomper
Probationer
Post by whomper » Wed Jul 21, 2010 5:52 pm
you just gotta love windoze
never a dull moment
Jinro
Post by Jinro » Wed Jul 21, 2010 6:14 pm
I love XP. I've had nothing but problems with Vista, 7, and Macs
whomper
Probationer
Post by whomper » Wed Jul 21, 2010 7:03 pm
preach to the choir
i bought spare copies of the oem xppro cd rom in case i ever need a new pc then i can still put xp on it
