Rickenbacker
Post
by Rickenbacker » Sat Jul 17, 2010 11:50 pm
I checked this page for help 1st :
http://wiki.audacityteam.org/index.php? ... shRecovery
I went to "Edit/ Preferences/ Directories" tab, & did see an 'audacity_temp" file address/ location. But after trying some Audacity recovery program I downloaded, it asked me to make a location or something, so I did, it then asked me to restart Audacity. I did- but then the temp location address was gone.
Now what?
- Quality Assurance
Post
by Gale Andrews » Sun Jul 18, 2010 2:27 am
Rickenbacker wrote:I checked this page for help 1st :
The crash recovery program for Windows is
http://www.mesw.de/audacity/recovery/ or
http://2by2.info/aud_recover-1.1.1.zip. The tool from mesw.de will ask you to specify the location of the .au files. I have never known those tools ask for Audacity to be restarted. Restarting Audacity 1.2 would not create a problem even if you did so before starting the recovery, as long as you told it not to delete temporary files. If you are actually using Audacity Beta 1.3, the temp files are deleted after you exit Audacity, as the Crash Recovery page states.
The recovery files will be created in the directory you specified in the crash recovery tool and will not be deleted by Audacity. Their names are in the form
recovery_blockx_channely.wav, where "x" is the recovery block number and "y" is the channel number (for stereo, "1" for left and "2" for right channel).
Rickenbacker
Post
by Rickenbacker » Sun Jul 18, 2010 4:13 am
Thanks, Gale.
The 1st link you gave is the site I went to. I guess me being a novice w/ this tool doesn't help matters. I may've typed the wrong thing in. I don't know. I've never used it. I thought it'd be more straightforward. But I do know I never asked it to delete my file, so I'm *assuming* it's still around somewhere. I hope.
whomper
- Probationer
Post
by whomper » Sun Jul 18, 2010 5:18 pm
how did you look for it ?
if you do start>search in windoze
for all folder/files named
*.au
windoze will find it else
nothign found then it is gone gone gone
Rickenbacker
Post
by Rickenbacker » Sun Jul 18, 2010 7:40 pm
...Ok, Win. Search found em, but I'm not sure now how to put it back in Audacity. I highlighted all the "b00##s" then right-clicked to try opening with Audacity. Didn't work. =/
- Site Admin
Post
by steve » Sun Jul 18, 2010 9:00 pm
Try opening Audacity, then from the "Project" menu select "Import Audio". Navigate to the folder where the .au files are located, select the files that you want to import and click the "Open" button.
Rickenbacker
Post
by Rickenbacker » Sun Jul 18, 2010 10:33 pm
Thanks, Steve
I opened Audacity, went to project/ Import Audio/ found my files, highlighted them & hit open. Then it asked me which program I wanted to open it with. I browsed & found & chose Audacity, then it just took me right back to the "Open With" dialog box. =/
- Site Admin
Post
by steve » Sun Jul 18, 2010 10:59 pm
Rickenbacker wrote:I opened Audacity, went to project/ Import Audio/
At that point a window should open for selecting the files that you want to open - You selected the files in
that window, not some other window?
Rickenbacker
Post
by Rickenbacker » Sun Jul 18, 2010 11:06 pm
No, from there, it took me to a window called "Select one or more audio files". But the files I needed were not there. I had to use the "look in" field's little black arrow to eventually get to them.
- Site Admin
Post
by steve » Sun Jul 18, 2010 11:16 pm
This is making less and less sense.
So you clicked on the "Look in" arrow, navigated to the folder where the .au files were, selected some of the .au files, clicked the "Open" button and it asked you which program to open them with?
Which version of Windows are you using?
