distortion
alec
distortion
Post by alec » Fri Jul 16, 2010 2:26 pm
I am transfering from a sony dat to a hard drive - line out>line in. The db level on the dat is mid scale, -12 to -4, viewed while recording or playback and sound is perfect, but Audacity meter reads at 0 and beyond during transfer, and the transfered sound is clipped. The sampling rate for the dat and audacity is set at 44.1hz. I am running windows XP.
whomper
Probationer
Re: distortion
Post by whomper » Fri Jul 16, 2010 3:35 pm
then between dat and audacity something is adding gain
lower it
if you cant lower it in the sound card or wherever
then lower the output of the dat
Re: distortion
Post by steve » Fri Jul 16, 2010 6:52 pm
There are different standards for "Line level".
Consumer audio equipment usually has a nominal level of −10 dBV
Professional audio equipment usually has a nominal level of +4 or +6 dBu
If the Sony DAT is using the professional standard, a full-scale signal will overload a consumer standard line level input.
It may be worth checking the manual for the Sony to see if the output can be switched to -10 dBV
Re: distortion
Post by kozikowski » Fri Jul 16, 2010 10:02 pm
<<<It may be worth checking the manual for the Sony to see if the output can be switched to -10 dBV>>>
Probably not. DAT machines are aggressively professional. Most of us without TV stations in our house use the headphone output and use the headphone volume control for output level.
