samson q1u usb in audacity beta
Did you buy a new mixer? Do you need advice? Post here.
john_t
Post by john_t » Sat Mar 15, 2008 1:23 pm
I am using the windows drivers for the microphone. Running on Windows XP.
I am having trouble recording in Audacity beta, using the same control panel and Audacity preferences settings as in audacity stable where I can record fine @ mono 44100Hz 16 bit PCM
My problem is that the mic will only record up to '-8' on the input level meter. There it seems to reach a wall. And clips at this point. In Audacity stable I can record normally up to '0' before it clips.
I want to use features in audacity beta which aren't in the stable version.
I can post screenshots if you don't understand what I am saying - I feel that I haven't explained it very well.
Can someone point out where I am going wrong, or what might be the trouble? I can answer further questions if you wish me too.
john_t
Re: samson q1u usb in audacity beta
Post by john_t » Mon Mar 17, 2008 8:42 pm
I have now tried changed the device (MME: Samson Q1U) channels to '2'.
And although it now records all of the left (it doesn't get stuck at around -8 anymore) channel and some of the other right, I can just silence the right.
The microphone records fine in 1.2.6 with just one channel selected though.
alatham
Post by alatham » Wed Mar 26, 2008 5:54 pm
This is something I've also noticed, and I'm not sure where the problem originates. It seems to be a subtle difference in the way audio drivers are used in the newer versions of Audacity. I have the same problem at working using an M-Audio MobilePre, it will clip at -3dB unless you record in stereo (though I think this is because both input channels are dropped by 3dB and then added together in order to record mono).
I wish I had a way to kill it, but until then your workaround is as good as it gets.
jnak222
Post by jnak222 » Wed Oct 01, 2008 8:53 pm
john_t wrote:I have now tried changed the device (MME: Samson Q1U) channels to '2'.
john_t, did you use the Softpre applet or did it work OK without it?
john_t
Post by john_t » Mon Dec 22, 2008 5:26 pm
Sorry for the late reply jnak222. No, I wasn't using the SoftPre, because when I tried to install it, my computer crashed and I had to roll back windows before it worked again.
However, I am now using a different PC on Vista-64bit and with an onboard Realtek sound thingy and the Samson Q1 mono recording problem is corrected with the latest beta version of Audacity. I don't know whether it's the new version of the software or the different PC, but it's worth mentioning for anyone looking into this problem.
