Edit help
biferi
Edit help
Post by biferi » Thu Jul 15, 2010 3:07 am
I have the new verson of audacity and would like to know how to make a sound fadout??
waxcylinder
Re: Edit help
Post by waxcylinder » Thu Jul 15, 2010 8:41 am
Select the portion of audio you wish to fade (use your cursor to click & drag to make the selection) - and then use Effect > Fade Out
biferi
Re: Edit help
Post by biferi » Thu Jul 15, 2010 5:55 pm
than you for the help but one more thing?
I see I select what I want to fadout and click effecs fadout. And it works.
But how do I get the amount I want to fadout?
If I want the fadout to be more do I just keep doing the same thing over and over agin???????
Re: Edit help
Post by kozikowski » Thu Jul 15, 2010 6:13 pm
The Fade Out effect happens over the duration of the timeline that you select. If you drag-select 20 minutes of show, then the effect will fade out for 20 minutes.
