Where to install Help Manual
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
Cushie
Post by Cushie » Sat Mar 08, 2008 7:47 pm
I have installed ver 1.3.4beta and have in the same folder the Manual manual-1.2 folder which was the version available at that time. Audacity is not 'seeing' this folder so where should I place it or configure it, so the the program help button can read it comprehensively?
Any help most appreciated.
Re: Where to install Help Manual
Post by steve » Sun Mar 09, 2008 4:41 pm
From the 1.3.4 README.txt file:
"Note that Help is no longer built in, but accessible on the Web via links in Audacity."
Cushie
Post by Cushie » Mon Mar 10, 2008 8:23 pm
I had not noticed that , thanks.
When you click on 'help ' tab you get a notice:-
"You don't appear to have Audacity help files on your machine. You can download the help files and then access them from Audacity as you have just attempted"
All it needs is the address of the index file in that link and it would work. Hope the final version allows for this.
Meanwhile it is doing a superb job of transferring my old LPs to mps.
Cheers
spoken22
Post by spoken22 » Sat Oct 18, 2008 11:45 pm
I have many manual installer in my computer here like you search but this version is not the same this is the local version or first version 0.3 installer manual. If you want to find more manual just search in any searching sites to find more output their.
