Crashing Audacity
LoZio
Crashing Audacity
Post by LoZio » Sat Mar 08, 2008 6:33 pm
I'm using 1.3.4 on Vista X64 (Dell D830 with 4 Gb RAM).
I found a way to crash Audacity. Here are the steps to reproduce:
1) Open a file (mine is 33 Mins)
2) Select a part of the file (about 3 min)
3) Crop to selection
4) Select a part of the remaing audio
5) Crop to selection
6) Make the stereo track a mono track
7) Normalize (0 dB)
8) Play. When you click play Audacity crashes.
I don't know if all the steps are necessary, but they are surely to crash Audacity (and loose my work, several times :cry: )
Hope it helps, and keep going on this good job!
Re: Crashing Audacity
Post by steve » Sun Mar 09, 2008 4:09 pm
LoZio wrote:6) Make the stereo track a mono track
There is a known bug that causes Audacity to crash after using "Stereo to Mono" (hopefully to be fixed in v.1.4).
The work around is to amplify by -6dB (minus six), then split the stereo track using "Split Stereo Track" in the drop down menu in the tracks information box, then using the same menu, set each track to mono and mix the two tracks together ("Quick Mix" in 1.2.x, or "Mix and Render" in v.1.3.x)
If both left and right channels are identical (it started off as a mono recording), the work around is even easier - simply split the track as described above, then delete one of them and set the remaining track to mono.
LoZio
Post by LoZio » Sun Mar 09, 2008 4:59 pm
Many thanks. Just a question: if it is a known bug, and it crashes the program loosing the data in it, why it should be fixed in 1.4.x since we're with 1.2 stable and 1.3 beta? Not kidding, real question.
Bye
Post by steve » Sun Mar 09, 2008 5:12 pm
LoZio wrote:why it should be fixed in 1.4.x since we're with 1.2 stable and 1.3 beta? Not kidding, real question.
The next stable release of Audacity will be 1.4 and it is based on the (almost stable) current 1.3 beta version.
breezewave
Post by breezewave » Mon Mar 10, 2008 9:51 am
I have a worse experience.
I have incorrect mono tracks from splitting single stereo track.
It sounds all right, but when I use Hex Workshop to see the binaries, the intensity values (maybe 1 %) aren't the same as stereo track.
1.2.6 stable is fine, but it occurs with 1.3.4beta.
And I have changed preference -> quality -> sampling rate and format to 48K/16bit, the same as my input.
My steps is:
1. drag file to audacity
2. split stereo track
3. close track of splitted right channel
4. mono
5. file -> export
So, is it a bug or my wrong manipulation?
I guess maybe the problem comes from a resampling that should not happen?
Thanks a lot.
Post by steve » Mon Mar 10, 2008 7:18 pm
breezewave wrote:My steps is:
4. mono
5. file -> export
I presume that your initial track was a 2 track mono recording (both channels identical)
For a true stereo track, the slightly longer method of mixing left and right should be used.
I've noticed that if I work in 16 bit, there are some tiny discrepancies, but they are in the order of -70dB, so it's not usually noticeable. Using 24 bit does not work on my machine (seems to be a common problem), but at 32 bit (float) it is "bang on" (bit perfect).
breezewave
Post by breezewave » Fri Mar 14, 2008 10:42 am
Yes, my initial track has two identical channels from a mono mic.
The discrepancies are really not noticeable, but this might result difficulties in debugging.
Oops, I don't want to mix, and nor do my steps.
If mixing, I believe maybe some algorithms are used due to psycho-perceptual things.
but I don't understand why a demux of simple stream copying have discrepancies.
1. change preference to 32bit
2. split
3. save or set sample rate to 16bit then save
1. preference of 16bit
2. set sample rate to 32bit
3. split
4. save or set sample rate to 16bit then save
Finally, I got 4 different files.
It seems a stable version is more stable.
Thanks a lot.
Post by steve » Sat Mar 15, 2008 1:55 pm
There will always be some slight "errors" when ever you convert from one bit depth to another due to "quantisation" errors. The audible effect of quantisation can be minimised by using "dithering" (which Audacity does by default).
You can read more about quantisation errors and dithering here: http://www.pcrecording.com/dither.htm
breezewave
Post by breezewave » Mon Mar 17, 2008 2:26 am
4. mono
5. file -> export
Did you mean that at 32 bit, I can get the bit perfect splitted one channel?
But at that time, I can't find out how.
Yes, I know what dithering is and what for.
But my input, output and edit->preferences are all the same sampling rate.
Theoretically, no dithering is needed, and I didn't think of it.
Anyway, after I turned dithering off, i got what I want and know what happened.
Thanks again.
Post by steve » Mon Mar 17, 2008 5:48 pm
breezewave wrote:But my input, output and edit->preferences are all the same sampling rate.Theoretically, no dithering is needed, and I didn't think of it.
I've not checked it out, but I think that Audacity may use 32bit internally. If I remember, I'll do some tests to check that later.
