Effects are all grayed out--why?
Do I need to do something in order to make the effects and other portions of Audacity that are grayed out usable?
Re: Effects are all grayed out--why?
Yes. Select some audio.
Thanks Koz. I had just gone back and experimented and was just returning to say that I figured it out.
I have had Audicity for almost a year, and never could get the effects un-greyed... I read KOZs answer, and chose a song, but still greyed out..I have tried it while playing audio, every thing I can think of but to no avail.. Please not to techinal..I am using
the 1.2.6 version with WIN XP and a Creative Sound card.. It didnt work before the Creative Sound Card..I would like to hear some more bass,and a touch of reverb at times... Thanks Marsh in Connecticut...
Just to clarify, by "select some audio" Kozikowski means click and drag to select a section of the audio track or use one of the Edit-Select options to make the effects menu available. He didn't mean simply opening a file, as your post implied. Also, effects are not available while Audacity is in Play or Pause mode.Marsh wrote:I read KOZs answer, and chose a song, but still greyed out..I have tried it while playing audio, every thing I can think of but to no avail.
Had a similar problem even though I HAD selected some audio. Turns out that the track can't be in "pause" mode. Hit stop and the effects got un-grayed. Hope this helps someone.
Possibly a bit late, given that you are replying to a post that is over 5 years olddndell wrote:Had a similar problem even though I HAD selected some audio. Turns out that the track can't be in "pause" mode. Hit stop and the effects got un-grayed. Hope this helps someone.
mickdonedee
Just started learning today and ran into the same problem when trying to use a Fade-out effect. I also noticed options in other menus greyed out so I figured the track was in a state that disabled those options. I quickly noticed that I had left the track in pause. Clicking the Stop button activated all the options again. Wish the video tutorials for beginners mentioned that at the beginning.
waxcylinder
As you can see from the earlier posts in this thread this has been a long-standing bear-trap for users to fall into. I still sometimes fall in and I've been using Audacity for many years now.
I would prefer it if Audacity just ignored the fact that Audacity was in Pause state and acted as though the user had pressed Stop instead and went ahead and just made the edit that the user requested.
There is a formal proposal for this on the Audacity Wiki: http://wiki.audacityteam.org/wiki/Propo ... Pause_mode
I have been discussing this with one of the developers recently so there is some chance that this may happen one way or another - but probably not in the next release as that particular developer is very busy doing other stuff.
waxcylinder
We don't provide any of those video tutorials - it would be far too much work for our very small documentation team to maintain and update those.mickdonedee wrote: Wish the video tutorials for beginners mentioned that at the beginning.
Most of those videos are using well out of date versions of Audacity and can thus be misleading - many are plain wrong.
You will learn better by following the written tutorials in out User Manual.
Link for the Manual: http://manual.audacityteam.org/o/#Tutorials
Top Tip: scroll up on the webpage from the link above (or click this link http://manual.audacityteam.org/o/#Guide ... ect_Window) and you will see an image of an Audacity project - you can click on places in this image to drill down and explore aspects of Audacity functionality.
