Audacity and Media Player on Windows 7 notebooks
Using Audacity and WMP12 on Windows 7 notebooks to capture music from records or tapes
Here is a short-form tutorial from start to finish:
Thanks to Gale Andrews, stevethefiddle, waxcylinder and kozikowski for all of the help in posts below; any remaining errors are all my fault
If you get stuck, see the Audacity wiki at http://wiki.audacityteam.org/index.php? ... uter_or_CD
1. The signal to be recorded must be passed from the record or tape player to the computer running Audacity. This will work best via a cable connected from the stereo Line Out jack of the tape player or phono turntable + RIAA pre-amplifier, to the stereo Line In jack (if available) on the computer. Devices connected to a ‘Hi-Fi’ amplifier can simply be switched through the amplifier Line Out.
• Other signal outputs (Headphone or Speaker jacks) are not as well matched to the computer inputs in volume or impedance, so generally result in more noise or distortion and may cause equipment damage.
If there is no available Line Out jack, the Headphone jack is worth a try, set to a very low initial volume.
Never connect from amplified speaker outputs to a computer – this will very likely damage the equipment.
• If the notebook computer lacks a Line In jack, you can use a USB input device such as the Griffin iMic or Behringer UCA 202 sound cards (or a USB turntable).
It may be possible to use a Microphone In jack. Unfortunately these are often mono inputs, and/or designed for lower signal strengths so it may not be possible to reduce settings enough to avoid clipping or other distortion.
An inbuilt or USB soundcard converts analogue sound signals into digital form, which can be used by Audacity.
A 24-bit (144 dB range) sound card (e.g. Roland UA-1G) may allow better quality than a 16-bit (96 dB range) card (e.g. Griffin iMic) … if (in the future) Audacity can record in 24-bit. See http://forum.audacityteam.org/viewtopic ... 3&start=40
2. If you require a USB input device, plug it into a USB port on the computer. Let Windows load the drivers automatically (works for Windows 7 pro and iMic2); or install them as for other added devices.
3. Check that the sound input path is enabled in Windows Sound Control (via Control Panel > Sound, or Right-Click the Taskbar Speaker > Recording Devices > Properties > General). Inputs may be designated as a Microphones by Windows. If desired, you can change the names to be more informative (like Mic In Jack, or iMic USB). Then check each Tab under Properties. Typically:
• Turn Listen off (you will more likely monitor the recording by software playthrough in Audacity).
• Note the Levels slider. This is one place where you can exert fine control over recording volume.
• Under Advanced, ensure that the Default Format is set to 2 channel, 16 bit, 44100 Hz (CD quality).
For the iMic, Windows initially gets this wrong, choosing mono; but it will then remember your settings (at least for the same device plugged into the same USB port). You might choose higher quality for a 24-bit card.
• You can choose to disable any unused microphones during this process if they interfere with recording.
4. In the Playback Devices tab, decide what you want as the default speakers.
• The default may become the usb adaptor. It can be changed back to the built-in speakers if preferred.
5. In Audacity (1.3.12 beta): under Edit > Preferences > Devices > Recording, choose the input device (e.g. the iMic USB or the Microphone in jack) and stereo. Project rate at bottom left of screen should match the quality set above (44100 Hz).
6. While in Audacity > Edit > Preferences > Devices > Playback, choose the desired playback device (the built-in laptop speakers in my case). Then under Edit > Preferences > Recording click Software playthrough if you want to monitor what is being recorded (with a slight delay).
7. In Windows 7, it is necessary to start Audacity after plugging in the iMic to have it appear properly in Audacity menus. Reboot if there is an "error while opening sound device".
• The Audacity volume sliders generally work well under Windows 7: double-click for fine control.
The input slider may fail to control as expected if you swap sound devices during a session. In that case either restart Audacity or control the input volume through the Windows Sound Microphone Levels slider mentioned in 3 above.
You can also drag the meters wider for a clearer look at real-time volumes, with a clipping alert at right.
8. Choose a loud track to set up recording volumes. Make a short test recording, using steps 11-12 below, with View > Show Clipping enabled. Reduce the volume if there is any red on the waveform.
• Ideally, adjust the input level so that loud sections are around -6 dB on the input level meter (equivalent to height of 0.5 on the 0-1 vertical scale of the Audio Track waveform) with no signal reaching 0 dB.
Audacity default settings (Preferences > Interface) display the waveform as +/-1 linear amplitude (like the voltage sent to a speaker) and the meters show from -60 to 0 dBFS. Background noise in many recordings is above -60 dB. The decibel (dB) is a log10 unit of intensity. Studio vinyl or Dolby master tape recordings had 70-80 dB of dynamic range. Human hearing spans < 140 dB from silence to deafening pain. For best use of available dynamic range in tape recording, loud sections were typically recorded up to 0 VU, which was set 8 dB below a specified distortion limit. Clipping was gradual as signal peaks approached tape saturation. Clipping sounds harsher in digital recording (unless filters are used, which bring their own problems) so it is better to allow more headroom and amplify later (step 15) if needed. See: http://manual.audacityteam.org/index.ph ... ng_Quality
Note that Audacity checks for digital clipping (signal near 0 dbFS). It can not tell if your analogue signal was clipped (e.g. by overloading a pre-amplifier in your sound card with an inappropriate input signal strength).
For more on this topic, see: http://en.wikipedia.org/wiki/Clipping_(audio) & http://en.wikipedia.org/wiki/Loudness_war
You can also confirm stereo in the Audio Track waveform: L & R tracks will differ slightly in places.
In my case using a HP Mini 5102 (and iMic2):
• With the iMic switch in Line position and the input level slider at 100%, loud sections were around -6 dB
But there was audible background noise in proportion to slider volume. If this exceeds vinyl noise or changes when the cable is touched, try a different cable, a more expensive sound card, or (last resort) noise removal in step 15.
• With the iMic in Mic position and input level slider at 0%, there were just a few clips at 0 dB
This setting gave the lowest background noise. It sounded OK on playback, but in addition to the flagged clipping there was substantial hardware clipping (strings of recorded signal points suspiciously just below 0 dB).
• The HP mini 5102 microphone in jack worked in stereo
But the line-in signal was too strong, even with the input slider set to 0, resulting in a lot of clipping when recording.
• The best combination should be amplifier Line Out through a quality USB sound card switched to Line In.
If all else fails, try the output from a Headphone jack to get adjustable signal strength into the computer (unfortunately generally with more risk of hum and other noise than from a Line Out).
9. The iMic is slightly microphonic (if you tap it you will see a spike in the signal) and it can pick up hum.
Keep it away from power supplies and any source of vibration or loud noise while recording.
If you get hum, it may disappear if you unplug your notebook power supply and record using the notebook battery.
10. OK, you are now connected, with volumes set and ready to record!
11. In Audacity, close (x) any test ‘audio tracks’, then click the Pause button, then the Record Button.
12. Lower the stylus, then click Pause to start recording.
Restart at a lower volume if any red appears in the waveform with View > Show Clipping enabled.
13. Stay alert near the end of your record side 1, and click Pause right after the last track finishes.
14. Flip the record, lower the stylus and click pause to have the flip side record tracks follow on in the same file. At the end of record side 2, click Stop (then turn off the turntable).
15. View > Zoom the displayed ‘audio track’ to a scale where you can easily see the quiet sections between record tracks.
• Move the cursor to these quiet sections and press ‘Ctrl B’ at each one to mark (Label) the breaks between tracks. Or you can try for automated detection of these breaks, by using Analyze > Silence Finder.
Check that you have marked the expected number of tracks (songs).
• From the Effect menu, you can if desired now Remove clicks or noise, Filter out wavelengths beyond human hearing (20 Hz – 20 kHz), and Normalize or Amplify to maximize volume without clipping.
Amplification to a peak level of -1 dB is recommended before export to MP3. See http://manual.audacityteam.org/index.ph ... ng_Quality
16. Use File > Export Multiple > MP3. Choose a destination Folder, ‘Split files based on Labels’ and ‘Name files by Numbering’.
17. Then click Export, and in the resulting ‘Edit metadata’ dialog box simply click OK for each track. Wait while Audacity processes the tracks to MP3.
18. There are a few settings to check in Windows Media Player (WMP version 12). These settings will be saved, so you do not have to do this afresh for each album. But on first use at least, check:
A. To avoid having WMP automatically mess with your files, under Tools > Options > Library,
Turn OFF:
Retrieve additional information from the internet…
Rearrange music files…
B. If you want to play in numeric rather than alphabetic order through a car auxiliary input, you may have set up for files to be named accordingly (##-song title) in WMP > Tools > Options > Rip Music > File Name. In that case, in WMP > Tools > Options > Library,
Turn ON:
Rename music files using rip music settings.
19. In WMP, Right-Click Music, then click Manage Music Library and add the Folder (if it is not already present). Then in Library > Music > Album view, it will show as an Unknown album.
20. To retrieve on-line information, right click the Unknown album. Select Find album info. Click 'selected tracks are from the same album', Next.
21. In the fai music window, enter known album information (artist and/or album name) in the Search box. Select the correct album. Click Next.
22. Select the track details in correct order. Click Next, Finish. That’s it!
• The album info (including track details and cover art) should now show in Windows Media Player.
In WMP12 album view, cover art will show from a folder on a local drive, but not a removable SD or USB.
• The file naming will be shown as ##-song title.mp3 in Windows Explorer.
Turn OFF:
Turn ON:
- Quality Assurance
Re: Audacity and Media Player on Windows 7 notebooks
R_G_B wrote:Using Audacity and WMP12 on Windows 7 notebooks to capture music from records or tapes
Thanks for all the details. The Wiki already has detailed setup instructions for Windows 7.
If you double-click the Audacity input slider you can enter finer values.R_G_B wrote:3. Check that the sound input path is enabled in Windows Sound Control (via Control Panel > Sound, • Note the Levels slider. This is where you can exert finest control over recording volume.
If a problem is repeatable, can you provide more detail of how to reproduce it and what form the confusion takes?R_G_B wrote:7.The Audacity volume sliders generally work under Windows 7, but can become confused if you swap sound devices during a session
This is probably because View > Show Clipping is more sensitive and flags every clipped sample. The meter clipping only triggers if there are four or more consecutive clipped samples.R_G_B wrote: The level meters also generally work, but the clipping alert sometimes fails when using the iMic input (check a section of a test recording, using View > Show Clipping).
Thanks Gale. Great tip to double-click the sliders for fine control. I edited it into the original post in case people find it useful to print out a straight instruction set.
The input volume slider lost control over input volume from the imic usb when I had been experimenting between the microphone in jack and imic usb inputs in an extended audacity session. I changed back and forth many times in that session. I could still control the imic input record volume through the Windows Sound microphone level slider. I think this is only likely to be experienced when people are doing such experimentation to work out the best input for their computer, and once they choose a preferred input and start a new session it will not be an issue. When I just use the imic usb input for a session, the Audacity input volume slider works fine.
I re-checked the clipping alert on the record level meter. It works fine on my system from the microphone in jack, but not from the imic usb input. For the latter, I can push the volume control slider up until the audio trace is solid red (with view > clipping) but there is just a blue bar at full scale on the record meter and no red alert in the clipping bay at right. Not a problem as long as users are aware of it and use a short test recording to ensure that they are not pushing volume into unexpected clipping.
Thanks again for all of the amazing work by the Audacity team.
- Quality Assurance
R_G_B wrote:The input volume slider lost control over input volume from the imic usb when I had been experimenting between the microphone in jack and imic usb inputs in an extended audacity session. I changed back and forth many times in that session. I could still control the imic input record volume through the Windows Sound microphone level slider. I think this is only likely to be experienced when people are doing such experimentation to work out the best input for their computer, and once they choose a preferred input and start a new session it will not be an issue. When I just use the imic usb input for a session, the Audacity input volume slider works fine.
OK thanks. I can't seem to reproduce a problem on Windows 7 changing between a USB sound card and the motherboard sound device, but I've made a note.
Not good if there are any runs of four or more samples that are clipped. We have had problems before that clipping is not detected on some hardware. Note if you are zoomed out it's easy to make the waveform appear solid red with View > Show Clipping without the clipping being that bad - generate a 30 seconds tone of 1.0 amplitude (which strictly isn't clipped but triggers View > Show Clipping to be on the safe side), then zoom in to sample level and you'll see how few samples are clipped.R_G_B wrote:I re-checked the clipping alert on the record level meter. It works fine on my system from the microphone in jack, but not from the imic usb input. For the latter, I can push the volume control slider up until the audio trace is solid red (with view > clipping) but there is just a blue bar at full scale on the record meter and no red alert in the clipping bay at right. Not a problem as long as users are aware of it and use a short test recording to ensure that they are not pushing volume into unexpected clipping.
Can you record 10 seconds or so from the iMic with the Audacity input slider set to maximum? If the meters show no clipping, do you see any labels if you run Analyze > Find Clipping with a Start Threshold of 4 and a Stop Threshold of 1?
Hi Gail,
I found that one way to force Audacity to lose control over input volume is to pull the plug with the incoming signal while the record level meter is still running (no need to be recording). This did the trick for the mic in jack (no control through audacity but full control through windows sound when the plug is reinserted to the same jack). It is shown in the top panel of the attached file (clipping.jpg) - assuming I worked out how to provide the attachment. I did not experiment further, probably similar effects apply to the usb input if the user pulls the plug at unexpected times. This loss of control through the audacity slider is easy to avoid, or to fix by restarting audacity.
The top panel in the attachment also shows that the clipping alert does work on microphone jack input. The lower panels are screen captures showing deliberate extreme clipping of a loud (L channel) input through the iMic usb input. The first screen grab in this set was taken while recording, with view clipping off - notice the level meter is pushed to far right without a clipping alarm. The lower screen grabs were after the short test recording, with view clipping on; then zoomed way in with view clipping on. I am sure this is real clipping (the volume was deliberately pushed a long way past the position where the moving bar on the level meter remained rammed into the right side of the scale)! But it does not show in the clipping box or with the analyse clipping settings that you mentioned. It is something odd about the way audacity perceives the signal from the iMic (USB) versus the Mic In jack (IDT 92HD75B) in my system. The same signal plugged into the Mic In jack triggers the clipping alarm as soon as the level is raised enough to let the signal bar hit the right side occassionally. Again, it easy to for users to avoid misinterpretation once they are aware of the caution. I only followed up in case it helps the audacity crew.
Regards, RGB.
Regards, RGB.
- Quality Assurance
Thanks. I don't have a working mic at the moment but I'll try that, also against what happens in the much older 1.2.6 version.R_G_B wrote:I found that one way to force Audacity to lose control over input volume is to pull the plug with the incoming signal while the record level meter is still running (no need to be recording). This did the trick for the mic in jack (no control through audacity but full control through windows sound when the plug is reinserted to the same jack).
R_G_B wrote:The top panel in the attachment also shows that the clipping alert does work on microphone jack input. The lower panels are screen captures showing deliberate extreme clipping of a loud (L channel) input through the iMic usb input. The first screen grab in this set was taken while recording, with view clipping off - notice the level meter is pushed to far right without a clipping alarm. The lower screen grabs were after the short test recording, with view clipping on; then zoomed way in with view clipping on. I am sure this is real clipping (the volume was deliberately pushed a long way past the position where the moving bar on the level meter remained rammed into the right side of the scale)! But it does not show in the clipping box or with the analyse clipping settings that you mentioned. It is something odd about the way audacity perceives the signal from the iMic (USB) versus the Mic In jack (IDT 92HD75B) in my system. The same signal plugged into the Mic In jack triggers the clipping alarm as soon as the level is raised enough to let the signal bar hit the right side occassionally.
Thanks for the trouble you went to. However if you got no labels from Find Clipping with Start/Stop settings of 4/1, this suggests the meter is detecting accurately for the trigger it requires to show clipping. You are still a long way off zoomed into sample level in the bottom image. Some devices will deliberately limit the input level so it can't clip badly - one of my older USB sound cards does that. If you still think there is clipping of four or more consecutive samples that is not detected by the meter, please upload a short demo wave file somewhere like http://www.dropsend.com/ .
Thanks
Hi Gale,
I am sure that you are correct that the clipping alert on the record meter is functioning as programmed - as per the Analyse > Find clipping using Start/Stop settings of 4/1.
On the other hand, I am fairly sure that 99.999% of users would want to avoid pushing the recording volume to a level that clipped 10,000 times per second (which in theory might not trigger the alarm at 44,100 samples per second). Even 10 or 100 clips per second throughout a track would generally be a sign to back off the volume to retain dynamic range in the recording.
My warning to Audacity users is that with some input paths (including iMic2 usb in the example shown) if users simply rely on the familiar clipping alerts on the record meters they are very likely to mistakenly push the record volume too high and severely reduce dynamic range in their recordings. We can use View > Show Clipping to avoid such scenarios, which will not show as clipping alerts on the record meters (by current design).
R_G_B wrote:Thanks Gale. Great tip to double-click the sliders for fine control. I edited it into the original post in case people find it useful to print out a straight instruction set.........
are all the easter eggs documented anywhere ?
who woulda thunk that double click would turn on fine control ?????
It's not an Easter egg, it's a feature that is documented in the manual: http://manual.audacityteam.org/index.ph ... er_Toolbarwhomper wrote:are all the easter eggs documented anywhere ?
- Quality Assurance
Grammar: "who would have thought".whomper wrote:R_G_B wrote: Great tip to double-click the sliders for fine control.
But I would agree this isn't really expected. What else could be done in the space to make it more discoverable isn't so obvious. It would be a bit tiresome to say "double-click for fine adjustment" in the tooltip, I think. Right-click has to be used to select the slider at the moment. My only idea is to use that little downward-pointing arrow (as in the Meter Toolbar) to access the precise adjustment dialogue. Now you can give us your brilliant idea as to what to do, Whomper
