How do you burn to a cd
winterfreak
How do you burn a recording to a cd? Any information would be helpful. On windows vista
Re: How do you burn to a cd
In Windows, as a fuzzy generality, you can open the song in Windows Media Player and one of the menus should ask you if you want to burn a CD. There are other CD authoring and burning programs you can buy; Easy CD Creator, Veritas, etc. and if you have one of those, you don't need Windows Media.
Sometimes, if you buy your CD burner separate from your computer, it will come with a simple authoring and burning program. That's how I got my Veritas.
