"separate" could mean either "remove" the vocals, or "isolate" the vocals (remove everything else except for vocals).mc ryan wrote:1 last thing do yu no how to seperate the vocal off a song cn you actually do that??
Both versions are discussed on this page: http://wiki.audacityteam.org/wiki/Vocal_Removal
Vocal Removal is relatively easy provided that the original audio track meets certain conditions - namely that it is a stereo track and the vocals are dead centre in the mix with no stereo effects on the vocal and the remaining instruments are not dead centre in the stereo mix.
Vocal isolation is much more difficult and will usually produce fairly poor sound quality (if it works at all, which it may not)
I have it on good authority that neither the CIA or the FBI are not in the business of making Karaoke backing tracks.
