Hi all,
I'm new to audio editing and audacity.http://www.baiaopharma.com/ I'm currently trying to split a large MP3 into several by just exporting each selection as I make it. One thing I can't seem to do is skip a bit of audio while צימר רומנטי>צימר-רומנטי it's playing. I expected to be able to drag the playing cursor but it won't let me צימרים . I don't know if it's just me or the facility isn't built in.
Is there a way to skip to a part of the selection you've made? If I try, the selection dissapears. سوق العملات
Thanks, http://kredite-vergleich.net/
Drag the play cursor?
alex weber
waxcylinder
Re: Drag the play cursor?
Don't know if it works in 1.2 - but certainly in 1.3 you can click your cursor at any point in the visible timeline (above the audio track) and the pay psotion will move to there.
Do you do video editing? What you want to do is called scrubbing. Moving the cursor back and forth over the edit point manually instead of letting the program do it.
JoooowitDah
Jooowit
wit
wit
it
[Mark-In]
And that's the other thing Audacity won't do. It doesn't have Mark-In and Mark-Out for an edit. The best you can do is set a Label which then becomes magnetic to set a real edit point later. And yes, that is awkward if your two edit points are an hour apart.
JoooowitDah
Jooowit
wit
wit
it
[Mark-In]
Labels did become a good deal more talented in Audacity 1.3.12. You might try that. You can safely install both versions, but only use one at a time. Audacity 1.3 projects will not open in 1.2.
