Reapair VST
bs1126
Reapair VST
Post by bs1126 » Thu Feb 28, 2008 10:50 pm
I have been using the Remove Noise effect and every time that I use the effect my sound becomes what a horrible quality, I dont know why. In addition, the EQ does not work properly cause when I used it my track become equalized and with a Fade In in the few seconds of it. Take a look at this features, thx.
Re: Reapair VST
Post by steve » Sun Mar 02, 2008 6:51 pm
The built in effects for equalisation and noise removal work fine in current versions of Audacity (when used correctly).
They are not VST effects.
