I tried to append record, but....
shroud
Post by shroud » Sat Jun 19, 2010 12:48 am
It says: error while opening sound device. Please check the input device settings and the project sample rate.
Re: I tried to append record, but....
Post by kozikowski » Sat Jun 19, 2010 2:10 am
You have contradictory complaints.
If Audacity can't Append Record, where did the original track come from? Typically, it's a really bad idea to mix and match different sound tracks.
shroud
Post by shroud » Sat Jun 19, 2010 4:03 pm
oh i thought append record was when you try to record on a recording without getting it smashed together (I want it to continue recording at the end of the recording, without having to scroll all the way to the end and clicking it and then press record).
shroud
Post by shroud » Sat Jun 19, 2010 4:39 pm
sorry i wasn't clear in my question. When I save an .aud file and then try to keep recording on the file, it records on top of the existing recording instead of on the end of it. How do u make the latter happen?
Post by kozikowski » Sat Jun 19, 2010 5:21 pm
I tried two different things in Audacity 1.3.12 on my MacBook Pro.
I made a simple recording and pressed Stop. I pressed Shift-R and Audacity put my new voice right on the end of the current recording no matter where my cursor is. I did it several more times and in each case, I got a new voice at the end of the old show.
I Saved The Project and closed the work window (but not Audacity).
File > Open and my saved performance arrived. Shift-R and I put a new voice at the end of the old Project.
I was doing this simple test with the built-in microphone of the Mac. So step by step, if you try that, where does it fail?
shroud
Post by shroud » Thu Jun 24, 2010 4:34 am
it worked on a new file, but i guess the other file was damaged somehow and didn't work on that.
Also, how do you replay from the last append record, not from the beginning?
Post by kozikowski » Thu Jun 24, 2010 2:35 pm
End the cursor before you Append. When you're done, playback should start from the Append point.
