Converting a directory full of aup files to wav
daviddoria
Post by daviddoria » Thu Jun 17, 2010 2:26 pm
Before I saw that there is a very convenient way of splitting a long track using labels and the "export multiple" command, I manually split a track into pieces and saved the pieces as a bunch of aup files. Is there anyway to now say "export all of these aup files to their respective wav files"?
Thanks,
Dave
bgravato
Re: Converting a directory full of aup files to wav
Post by bgravato » Thu Jun 17, 2010 2:36 pm
You have a batch mode processing feature in audacity. I never tried it, but I think it might do the trick...
http://manual.audacityteam.org/index.ph ... Processing
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
whomper
Probationer
Post by whomper » Thu Jun 17, 2010 3:12 pm
aup is a project not a file
au is a file type with pieces of the actual audio for the aup to use
audacity will handle picking the right au files to convert
when you export from the aup project
open the project for each file and then export
as a wav or whatever
put them all in the same directory
to make it easier to burn a cd next
else
go back to the saved version of the original
(you do back up dont you ?)
and then put in the labels and export multiple
take your pick - same amoutn of work either way
daviddoria
Post by daviddoria » Thu Jun 17, 2010 9:38 pm
So what I am trying to avoid is having to open all of the .aup projects and manually export each one. The batch 'apply chain' seems to want to operate only on audio files (not projects). Is there no scripting language that I can say "export everything in this aup project to a wav file" and then I can wrap that in a bash loop?
Dave
whomper
Probationer
Post by whomper » Thu Jun 17, 2010 11:26 pm
then go back to your original copy and export multiple
you do keep backups dont you ?
else you will have to do them one at a time
really not *that* big a deal to do
daviddoria
Post by daviddoria » Thu Jun 17, 2010 11:28 pm
Yes I have the original, but I already spent a lot of time splitting them where they needed to be split. Of course it's not THAT big of a deal, but if I'm not in a hurry and I could wait a few days and find a clever solution that would save me several hours, that sounds good to me :) Sounds like there is no way to batch do anything to these .aup's though :(
whomper
Probationer
Post by whomper » Thu Jun 17, 2010 11:30 pm
using the original and export multiple will do that the easiest way
